Activity Forums Adobe Premiere Pro Time-Lapse compilation in Premiere? Can it do this?
  • Time-Lapse compilation in Premiere? Can it do this?
    Posted by Rudy Shalamar on January 25, 2010 at 7:36 pm
    Hello,
    I will be creating many time-lapse videos from thousands of still images.
    Is this something Adobe Premiere Elements 8 can handle easily?
    Is this the right simple program to get the job done?
    Thank you!!!
    Rudy
    Mike Mcmahon replied 16 years, 8 months ago 3 Members · 2 Replies
  • Ann Bens
    January 25, 2010 at 10:46 pm
    Yes, make sure the stills have the same dimension as the project.
  • Mike Mcmahon
    January 26, 2010 at 2:21 am
    Also, be mindful of the overall file size of the images. A .psd or .tiff file will usually be much larger than a comparable .jpg with the same pixel dimensions. Premiere Pro & Premiere Elements are very sensitive to the overall load caused by multiple images. I have the scar tissue to prove it.
    I suggest you find the smallest jpg sizing that will still look good when displayed in your final project (DVD, online gallery, etc.) and run a few tests as you increase the number of images. And save your work often to guard against system crashes.
    Let us know how it goes. Working with still images doesn’t get enough reference/support in the Premiere world…it’s often glossed over in instruction books and online help.
    – Mike –
