Activity Forums Adobe Premiere Pro Time indicator navigation problem
  • Time indicator navigation problem
    Posted by Willem Scholtes on June 11, 2013 at 10:04 am
    Dear creative cowers,
    “Something” happend yesterday. For some reason that i dont know, i cant move the time indicator anymore with my arrow keys. I still can move from clip to clip with the up and down arrows, but left and right dont do what they used to do. Also with the cmd key pressed it doesn’t work.
    Also (as you can see in the attached screenshot) i have now three decimals after the comma when it used to be just two. Don’t know if that is related to each other but i just noticed that that was different to.
    This is very frustrating because i’m at the stage where moving clips frame by frame is essential. If anyone has the answer then i would be very very grateful!
    Kris Merkel replied 13 years, 2 months ago 2 Members · 1 Reply
  • Kris Merkel
    June 11, 2013 at 3:18 pm
    Select the pulldown menu in the top righthand corner of the sequence window and deselect “show audio time units” your timeline numbers should then return to default. As far as the moving the playhead with the left and right arrow keys are concerned go into your keyboard shortcuts and make sure they are set to the default or select one of the preset layouts and reload it. That should solve the problem.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
