Activity Forums Adobe After Effects Time indicator jumps ahead
  • Time indicator jumps ahead
    Posted by Kent Wallis on September 21, 2016 at 4:21 am
    I’m trying to create a video loop to match a piece of audio. Usually I can just change the duration of the video to half the audio length, duplicate and reverse it to loop. For some reason I can’t time stretch this video properly. When I choose a duration of 05:59 it changes this to 06:29. I can’t even make a new composition of 05:59 without it changing. After trying many work around’s I noticed that when I scroll through a composition my preview time readout goes from 05:29 to 06:00. I opened an old project and going frame by frame the time jumps from 05:24 to 06:00. It’s even happening in premiere pro, it jumps from 05:29 to 06:00. I’ve closed and reopened both programs and rebooted. Any ideas?
    Kent Wallis replied 9 years, 12 months ago 2 Members · 3 Replies
  • Tudor “ted” jelescu
    September 21, 2016 at 8:31 am
    What frame rate are you working at? It seems to me you are describing various frame rates 05:29 to 06:00 would be a 30fps (29.97) and 05:24 to 06:00 would be a 25fps.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
  • Kent Wallis
    September 25, 2016 at 8:16 am
    Sorry for slow response. Had to go out of town for work. The footage is 30fps. Based on a post in the adobe forums I’ve tried changing it to 29.97, 23.976, and 25 but it still jumps ahead at around the same time.
  • Kent Wallis
    September 25, 2016 at 10:24 am
    Got this from the adobe forums so I think I’ve figured it out now. Thanks for the help.
    “yep, that’s the way it’s supposed to be. here you are looking at time code of 25fps – it means that every 25 frames, a second passes. so 05:25 is 06:00”.
