Activity › Forums › Adobe After Effects › Time Freeze Effectt
  • Time Freeze Effectt
    Posted by Soham Jani on December 13, 2015 at 2:16 am
    So just watched the Matrix, and saw the 360 time freeze effect. Problem? I only have one DSLR. So is there a cheap way to achieve a similar effect? Like moving the camera around on a tripod at a certain shutter speed? Anything? Plz I’m doing a project on the Matrix related things so I need a way to do something like this. Thanks!
    Jim Arco replied 10 years, 9 months ago 3 Members · 6 Replies
  • Paul Esteves
    December 13, 2015 at 9:51 am
    Unfortunately, I think you’re out of luck. It’s not possible to achieve this look without a time-splice rig (a bunch of cameras). If it’s for a paid gig, hire a rig out and use it for the stuff you need.
  • Jim Arco
    December 13, 2015 at 2:35 pm
    There have been several rather successful “single camera” time slice techniques. They range from a rig that moves the camera around (while the actors remain frozen), to complicated post techniques where you cut a still images into layers and manipulate them in AE.
    None of them can achieve exactly what a multi-camera rig can achieve, but you can get very convincing results, trading production/post-production time for cost.
    Try youtube or even big-G with “time slice,” “time freeze,” or “bullet time with one camera.”
    Jim
    Colorburst Video
  • Soham Jani
    December 14, 2015 at 10:30 pm
    What about me slowly doing the scene with the camera moving around me and motion tracking green screen footage of a bullet traveling across the screen at a certain angle to me and the footage will stick to me while the bullet in the footage will move across me?….kinda get what I’m saying?
  • Jim Arco
    December 16, 2015 at 1:43 pm
    Instead of shooting “green screen footage of a bullet traveling across the screen” you could just 3D animate a still image of the bullet, then add the air-turbulence typically seen with slo-mo projectiles.
    Jim
    Colorburst Video
  • Soham Jani
    December 17, 2015 at 7:32 pm
    How do you animate a still image? If it’s still, then enabling the 3D toggle probably won’t make it look that great…
  • Jim Arco
    December 18, 2015 at 11:41 pm
    Paul,
    I was referring to moving an image of just a bullet around in the comp to simulate a bullet traveling across the screen. So put the bullet on one side of the comp, set a keyframe, then move the bullet to the other side and set another keyframe. Or put a 3D bullet on a 3D layer and move it in three dimensions.
    Jim
