Activity Forums Adobe After Effects Expressions time expression with 60fps – unexpected results
  • time expression with 60fps – unexpected results
    Posted by Patrick Grossien on August 10, 2015 at 6:28 pm
    I tried to use Dan Ebbert’s script below to hold a position of a layer for 12 seconds. Unfortunately I’m working with 60fps and the script doesn’t work as it should. It holds the position for more than 12 seconds.
    I haven’t fully grasped what the “time” function actually delivers. Especially with higher frame rates. Any help is much appreciated.
    holdTime = 12; //time to hold each position (seconds)
    seed = Math.floor(time/holdTime);
    seedRandom(seed,true);
    random([thisComp.width, thisComp.height])
    Patrick Grossien replied 11 years ago 2 Members · 5 Replies
  • Dan Ebberts
    August 10, 2015 at 6:34 pm
    time is in seconds and is independent of the frame rate. The expression works fine for me at 60 fps. Do you have time remapping in the mix somewhere?
    Dan
  • Patrick Grossien
    August 10, 2015 at 7:03 pm
    Thank you Dan for helping me out!
    There’s no time remapping in there.
    I’ve randomised an ellipse with turbulent displace and rotation.
    Scale has looping keyframes from 00:00:00 to 00:12:00 (also tried 00:11:59)
    and the repositioning always happens after 12sec and it’s multiples.
  • Patrick Grossien
    August 10, 2015 at 7:09 pm
    I tried it in a clean comp with a simple circle and it jumps at
    00:12:24
    00:24:24
    it always switches 24 frames after the given second.
    If I use 11 seconds as hold time it jumps at
    00:11:24
    00:22:24
    so it’s as if I’m missing something in the overall comp settings or preferences then?
  • Dan Ebberts
    August 10, 2015 at 7:13 pm
    Does the layer start at comp time = 0? If not, you might want to try it this way:
    seed = Math.floor((time-inPoint)/holdTime);
    Dan
  • Patrick Grossien
    August 10, 2015 at 7:16 pm
    Oh man, I guess I’m just totally overworked. I can’t see the simplest things today….
    Yes that’s it and the script works like a charm like that.
    Thanks a million!
