Activity Forums Adobe After Effects Time Display Settings
  • Time Display Settings
    Posted by Charles O’connor on April 20, 2016 at 12:17 pm
    I understand how to switch from frames to seconds, but I am having trouble figuring out how to subdivide my seconds in my composition. My project is 10 seconds long, and I am only able to select one second on the mark in my timeline. How can I get the program to display different intervals such as x.1 seconds? When I scrub through it just snaps to each second and I have no way to place a keyframe at, say, 5.5 seconds.
    Walter Soyka replied 10 years, 5 months ago 3 Members · 2 Replies
  • Soham Jani
    April 20, 2016 at 1:03 pm
    Did you try changing the settings in the composition settings? It might be in the After Effects settings.
    \”It\’s all around us Neo, temporary constructs of time…..\”
  • Walter Soyka
    April 20, 2016 at 2:30 pm
    [Charles O'Connor] “My project is 10 seconds long, and I am only able to select one second on the mark in my timeline. How can I get the program to display different intervals such as x.1 seconds? When I scrub through it just snaps to each second and I have no way to place a keyframe at, say, 5.5 seconds.”
    That will be based on your frame rate. For example, if your comp is 30 fps, 5.5 seconds will be 5 seconds and 15 frames.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
