Activity Forums Apple Final Cut Pro Legacy time & date code transfer
  • time & date code transfer
    Posted by Steve Tamou on July 8, 2010 at 12:35 am
    After transferring the video file from my sony avchd camcorder to FCP, I don’t know if the time and date code gets transferred with the file. And, if I delete the file from the camcorder, the time & date infromation will be lost. Am I supposed to manually put that infromation in at log and transfer? Thank you in advance.
    Colin Browell replied 16 years, 1 month ago 4 Members · 3 Replies
  • Jerry Hofmann
    July 8, 2010 at 1:30 am
    FCP doesn’t read that metadata, so you’ve guessed right, need to do this during Log and Transfer manually, or after the fact in a description column in the Browser one clip at a time…
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jon Smitherton
    July 8, 2010 at 1:51 am
    Yes there is a need for this – hopefully this feature will be in the next version – you can read up on a discussion here:
    https://www.larryjordan.biz/articles/lj_metadata.html
    There is a tool for this; however, it costs –
    https://assistedediting.com/miniME/
    Jon
  • Colin Browell
    August 7, 2010 at 9:59 am
    If you have access to a Windows PC, “DVDate” and “DVMP Pro” may help too.
