Activity Forums Apple Final Cut Pro Legacy Time Code WIndow
  • Time Code WIndow
    Posted by Neal Klaeser on February 2, 2009 at 2:29 pm
    I would like to output a QT file with a t.c. window burn-in for approval by clients. Most of my projects are mostly an hour or more. I tried using the time code generator filter and found that the render before output was more than an hour. Is there a fast and simple way to accomplish this?
    John Fishback replied 17 years, 7 months ago 4 Members · 6 Replies
  • Walter Biscardi
    February 2, 2009 at 3:27 pm
    Use Compressor to generate it when you compress the file for client review. It renders MUCH faster.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Neal Klaeser
    February 2, 2009 at 4:21 pm
    Sorry. Were can I find this setting in Compressor.
  • Walter Biscardi
    February 2, 2009 at 4:43 pm
    Look in the filters tab
    Read my Blog!
  • John Archer
    February 2, 2009 at 8:18 pm
    like original poster, often have to provide a file with burnt in timecode to give to client, either a DVD or an MPEG1. Where is the timecode generator in Compressor? I have looked in the filters tab ( I have compressor2) and don’t see it among the available filters.
  • Neal Klaeser
    February 2, 2009 at 8:26 pm
    By double clicking on the narrow rectangular window near the top left of the screen, open up the inspector and there will be a row of icons in the inspector window. The fourth window from the left will be “filters”, click the video tab and scroll to Time Code Generator and click the box. Be sure to change the color of the numbers to white. Because I was doing a test over color bars and couldn’t see the numbers because they were keyed over the black portion of the color bars. Duh!
  • John Fishback
    February 2, 2009 at 9:13 pm
    Another possibility is to place a t/c generator over your timeline and play in realtime into a dvd recorder. There’s Andy’s Timecode Generator which is a true generator, not a filter.
    https://web.mac.com/andymees/Free_and_Easy/main/Entries/2005/9/5_Andy%E2%80%99s_Timecode_Generator.html
    Often this plays without rendering.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
