Activity Forums Apple Final Cut Pro Legacy Time code window
  • Time code window
    Posted by David Donnenfield on April 17, 2008 at 5:48 pm
    When I used to shoot tape, creating a “window dub” was a snap. With P2 files, I’m wandering in the dark. Presuming one can, how does one display the camera’s recorded time code on acquired media and then output this to either DVD or, egads, VHS tape? Basically, my client needs to review field material and make selects.
    David
    Walter Biscardi replied 18 years, 4 months ago 4 Members · 4 Replies
  • Fred Miller
    April 17, 2008 at 5:56 pm
    Apply TC reader filter that is located in EFFECTS Bin. Make DVD or VHS dub.
    PS
    Make SURE you get the TC READER and NOT TC Generator!
    FCP Studio 2
    Dual 3Gg Quad Core
    5Gg RAM
    KONA 2
    OS 10.4.11
  • Jeff Carpenter
    April 17, 2008 at 5:58 pm
    Once you get it in Final Cut, there’s a Time-Code filter you can drop on it. Then either export to a web file, a DVD, or run it off on tape.
    Be careful to note: There is a time code filter that starts with a number you put in and goes up from there, and there’s another filter that reads the embedded time code and shows that number. That’s the one you want, so make sure you’re using the right one.
    They’re both in a folder called “Video” in the effects bin.
  • David Donnenfield
    April 17, 2008 at 10:49 pm
    Jeff, Fred,
    Thanks so much for the quick response. I’ll give it a whirl.
    David
  • Walter Biscardi
    April 18, 2008 at 1:08 am
    [Jeff Carpenter] “There is a time code filter that starts with a number you put in and goes up from there”
    Timecode Generator.
    [Jeff Carpenter] “there’s another filter that reads the embedded time code and shows that number.”
    Timecode Reader.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
