Activity › Forums › Adobe After Effects › Time Code Start Time
Posted by Christopher Rotter on June 20, 2009 at 4:35 amThe CTI (current time indicator) always starts at Zero. Is there a way to shift that to start at XX number of frames or seconds, and then restart it back to Zero when needed ?
Christopher Rotter replied 17 years, 3 months ago 4 Members · 7 Replies -
Todd Kopriva
June 20, 2009 at 4:18 pmYes, you can change the Start Timecode. As with all composition settings, the value that you set becomes the default for new compositions, too.
I found this by entering your subject line into the After Effects Help search: timecode start time
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
Christopher Rotter
June 20, 2009 at 7:01 pmHow can I change the current time indicator so that frame or second Zero (“0”) can be located some where else on the time-line ?
David Johnson
June 20, 2009 at 7:11 pmI doubt this will work (or that there even is a way to do that), but the first thing I’d try is doing what Todd said and set the start timecode to a negative value.
Christopher Rotter
June 20, 2009 at 7:17 pmWell I want to be able to shift the zero time start, but if I can’t.
