Activity › Forums › Adobe Premiere Pro › Time Code reference for client DVD
  • Time Code reference for client DVD
    Posted by Mike Healey on October 19, 2009 at 5:07 pm
    Hey gang – I’ve got several P2/MXF clips from a project I’ve shot and need to provide a time code DVD for the client to review off line. In CS3 I usually just drop all the source clips in order onto the timeline, create a transparent video layer, drop time code effect on that layer and it usually works.
    In this case, I have selected several good takes and dropped them on the timeline but the time code always starts at 00:00:00:00 and the clips are not in order or start at 00:00
    Is there a method I’m not aware of to export a time code burn using the actual time code from each clip?
    ~Mike~
    Mike Healey Productions, Inc.
    create | shoot | edit | deliever
    http://www.MikeHealeyProductions.com
    Mike Healey replied 16 years, 11 months ago 4 Members · 5 Replies
  • Vince Becquiot
    October 19, 2009 at 8:05 pm
    Because you want clip specific timecode, you have to apply it to each clip and change the timecode setting to media.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jon Barrie
    October 20, 2009 at 1:20 am
    What Vince said… Check this Video Tutorial about BITC if you’re not sure…
    https://www.youtube.com/watch?v=xMx0YIZGN1Q
    – Jon Barrie
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Mike Healey
    October 20, 2009 at 1:33 am
    Thanks guys! I applied the time code to the first clip, tweaked the settings and did a copy and paste to the remaining clips and all is well and in sync. I never realized you didn’t have to create a transparent video layer to add time code. I don’t know where I even saw that but it doesn’t matter now. I got it working correctly. Thanks!
  • Jeff Brown
    October 20, 2009 at 1:18 pm
    I think you _do_ need TC on a separate layer if you want to have “timeline timecode” instead of per-clip TC.
    -jeff
  • Mike Healey
    October 20, 2009 at 2:03 pm
    Yeah I forgot about timeline code. That is correct.
