Activity › Forums › Apple Final Cut Pro Legacy › Time code on capture now
Posted by Andrew Flood on March 6, 2006 at 10:37 pmUsing a HVR-ZU1 running time of day code I would like to capture DV footage to a firewire drive through my 17 inch powerbook running FCP-5. “Capture Now” works when “Device Control” is set to “Non-Controlllable Device” but there is no code transfer from camera. Any other setting gets a small clip with correct code but capture aborts with a message that I am at the end of tape. Anyone solve this issue?
Andrew Flood replied 20 years, 6 months ago 3 Members · 5 Replies -
Walter Biscardi
March 6, 2006 at 10:50 pm[Andrew Flood] “”Capture Now” works when “Device Control” is set to “Non-Controlllable Device” but there is no code transfer from camera.”
Nope, no timecode when in non-controllable device.
Are you set to “Create a New Clip” at TC break? Obviously with time of day you’re going to have a TC break everytime the camera stops.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Andrew Flood
March 6, 2006 at 11:16 pmI am trying to do a poor man’s Focus Firestore. I intend to roll tape in the camera during an event but I am trying to simultaneosly digitize the footage. Since I will be in a fixed position I can set up the laptop and firewire drive. I am trying to avoid 6 hours of digitizing.
So I do have “Make new clip” selected. The timecode should not stop since it is on free run. I can see the timecode in the log and capture window when I select a firewire device in the “Device Contol” drop down menu. Time code goes away when I select “Non-Controllable Device”
Thanks for your idea. Apple does not seem to want me to do this. -
Walter Biscardi
March 7, 2006 at 12:58 am[Andrew Flood] “I intend to roll tape in the camera during an event but I am trying to simultaneosly digitize the footage.”
This doesn’t work with FCP 5 or even 4.5. It used to work perfectly with FCP 3, but I have not been able to digitize on the fly via Firewire any longer since FCP 3.
Ben Oliver
March 7, 2006 at 7:01 pmhmm……ive done this recently with 4.5.
short clip tho, like, 3 mins.
i set up my camera, firewire into the hd, then hd to apple ibook g4, then hit capture now while in non-control device.
i wasnt runnin tape tho. perhaps that is a reason?
-ben
Andrew Flood
March 9, 2006 at 2:09 amBut did the timecode on the clip start at zero or did it have the code from free running code on camera?
In FCP-5 it seems to allow the capture on the hard drive it just makes up it’s own code. I want to have
the same code on the hard disk as the code on the tape. I appreciate your try. Andrew Flood
