Activity Forums Adobe Premiere Pro time code of clip viewable in canvas + clip split question
  • time code of clip viewable in canvas + clip split question
    Posted by Alexandre Brandt on July 17, 2013 at 1:52 am
    Hello folks.
    Still exploring the software and I’m bumping into a small issue with some HDV 1080p25 with clip splits.
    I have some clips that go over to files. I work on a mac so I can’t use the Sony recording utility which links the files to one clip (PC application).
    So I put all my clips in a timeline but there is a cut in sound when one file goes to the next (in the case of split clips).
    I am very sure that the 2nd part of the file actually has a bit of media of the 1st part so that no footage is lost. I’d like to find a way to correct that so that Premier can match my clips if their is an option for that.
    I wanted to do it manually but then I run into another issue. Where can I get the clip (not timeline) timecode to show in the canvas ?
    Thanks !
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Alexandre Brandt replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
