Activity Forums Apple Final Cut Pro Legacy Time Code issues
  • Time Code issues
    Posted by Smith Glover on February 23, 2009 at 7:43 pm
    Hello,
    I am trying to capture footage from a tape shot on a busted camera. Unfortunately, the tape has odd and inconsistent time code- it registers while fast forwarding that the TC is there, but there are tons of breaks and glitches. As a result, when I digitize, the FCP has to stop and re-locate every 10 seconds or so. Is there a way to force it to import the footage. even if the time code isn’t registered properly? Then I could export on another tape and get the TC that way (OK, I lose a generation of quality, but I don’t mind).
    Smith
    Rafael Amador replied 17 years, 7 months ago 3 Members · 5 Replies
  • Shane Ross
    February 23, 2009 at 7:49 pm
    Switch deck control to UNCONTROLLED DEVICE. Then you have to control the camera manually, but you can capture. And FCP will ignore the code on the tape…so after you capture, back this footage up somewhere, in case something happens to the main footage, like a drive failure.
    Shane
  • Smith Glover
    February 23, 2009 at 7:55 pm
    Shane- thanks for the response. I am capturing with a Sony HVR deck- you are saying that I need to switch to UNCONTROLLED DEVICE on that deck, and then capture, or is UNCONTROLLED DEVICE a setting in FCP?
    Thanks again.
  • Shane Ross
    February 23, 2009 at 8:02 pm
    It is a setting in FCP…CAPTURE SETTINGS tab in the CAPTURE window.
    Shane
  • Smith Glover
    February 24, 2009 at 2:42 am
    shane- worked great- thanks for your help.
  • Rafael Amador
    February 24, 2009 at 5:24 am
    [Smith Glover] ” Then I could export on another tape and get the TC that way (OK, I lose a generation of quality, but I don’t mind)”
    As long as you don’t render in FC or export in QT, no generation lost.
    rafael
    http://www.nagavideo.com
