Activity Forums Adobe Premiere Pro Time Code is incorrect
  • Time Code is incorrect
    Posted by Steve Wargo on February 2, 2013 at 9:41 pm
    I have a 1hr 44min project but when I lay in a transparent video track and put a time code filter on it, the time code says that the program is 1hr 22 min long.
    Seems like I need to set something – what could that possibly be?
    CS6, Cloud on ProMax Hero
    Steve
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
    Ask me how to Market Yourself using Send Out Cards
    Tero Ahlfors replied 13 years, 7 months ago 3 Members · 2 Replies
  • Victor Perez
    February 2, 2013 at 11:12 pm
    Does the frame rate of the Timecode filter match the sequence? I think you might have a 24 frame sequence with the Timecode Filter set to a higher number. This will give you a shorter total time according to the filter because there are more frames per second.
    Hope that helps
    Victor
    editvictor.com
    http://www.hbhm.tv
    http://www.itvisus.com
  • Tero Ahlfors
    February 3, 2013 at 12:46 pm
    The timecode filter defaults to 30fps drop frame and there are other settings that you also might want to check.
