Activity Forums Apple Final Cut Pro Legacy Time code in vision
  • Time code in vision
    Posted by Rob Done on May 20, 2005 at 3:33 pm
    Is it possible to burn in the timeline timecode onto the output picture if a client needs it for reference on a VHS rough cut for example. This seems a rather basic function that I’m having trouble finding.
    Rob Done replied 21 years, 4 months ago 5 Members · 7 Replies
  • 7 Replies
  • David Scott
    May 20, 2005 at 3:43 pm
    Hi Rob
    It’s in filters/video/timecode generator. If your sequence has a lot of cuts I would nest it into another to produce one clip, then drop the filter on. You may need to render it.
    Cheers
    David Scott
  • Will Macneil
    It’s in video filters – video – timecode.
    Will
  • Rob Done
    May 20, 2005 at 4:13 pm
    Thanks guys, is there a way to get the whole timeline/canvas timecode in vision? Using this filter looks like I can either get individual TCs for each edit or (as David suggests) I have to render the whole timeline down to one clip which is not ideal. (Ex *edit user, couple of mouse clicks and you had it!)
  • Rob Done
    May 20, 2005 at 4:23 pm
  • David Jones
    May 20, 2005 at 5:32 pm
    How about new layer with say a box for the timecode that is the length of the project,
    with the filter applied.
  • Annaël Beauchemin
    May 23, 2005 at 5:21 am
    Read David Scott’s post.
    You need to nest your sequence and apply the timecode reader on the nested sequence.
    I often had to do it for VHS previews and a G5 2×2 manages to play it in realtime full quality. This saves alot of render time. But be sure to select Squence -> Render Only -> Needs render and also do an audio mixdown or you’ll have surprises…
  • Rob Done
    May 23, 2005 at 8:30 am
    V helpful thanks
