Activity Forums Apple Final Cut Pro Legacy Time Code Error:
  • Time Code Error:
    Posted by Deyson Ortiz on June 15, 2005 at 6:28 pm
    Hello 🙂
    Here is my problem, I have 20 hours of multicam footage to capture, unfortnatly they have timecode breaks all over, I set it to warn after capture, but it still gives me a timecode error at the end of capture and it does not save it to the drive.
    We never had a problem before, and I was wondering if its a Final Cut 5 problem?
    the only way I got it to work, is with capture now.
    Thank you
    Deyson
    Dual 2.7
    AJA Kona 2
    Capturing 1080i HD as DVC Pro HD
    Final Cut 5
    Grant Keiner replied 21 years, 3 months ago 2 Members · 1 Reply
  • Grant Keiner
    June 25, 2005 at 5:00 pm
    I am having the same problem with Final cut 5.
    I have found that I can capture in 4.5 without a problem.
    I am thinking about trying a different Firewire protocol in FCP 5. Have you done this?
    have you found out what is causing the problems?
    Grant Keiner
