Activity Forums Apple Motion time changes
  • Adolfo Rozenfeld
    November 6, 2005 at 6:06 pm
    By speed changes, you mean slow/fast motion or variable speed? If it’s the first thing, you just have to go to the media tab in the inspector (select the object and hit Shift-F) and change the Frame Rate setting.
    For simple time remapping, you have the scrub filter (Add Filter > Time > Scrub). The frame offset parameter allows you to control a virtual playhead.
    Hope this helps.
    Adolfo Rozenfeld
    Buenos Aires – Argentina
    https://www.adolforozenfeld.com
    adolfo@adolforozenfeld.com
