Activity Forums Apple Final Cut Pro Legacy Time Capsules dying
  • Time Capsules dying
    Posted by Steve Knattress on October 14, 2009 at 4:38 pm
    Just as a precaution, if any of you use the apple time capsule to back up your projects and other data, I should make a back up now!
    My time capsule (March 08 vintage) died earlier last week.
    From messages on the apple TC forums it would appear that the capacitors in the internal power supply are failing probably due to overheating because of the poor ventilation design after approx 18 months.
    Apparently the drive is fine, if removed into an external caddy.
    Apple have refused to replace mine since it is out of warranty.
    Others have had them replaced under apple care, although no data recovery was made available.
    There is a memorial site https://timecapsuledead.org/
    Please back up data now before its too late.
    Ben Holmes replied 16 years, 6 months ago 2 Members · 1 Reply
  • Ben Holmes
    October 14, 2009 at 8:28 pm
    I would never recommend any backups to a device without server-grade drives (which the time capsule lacks anyway) although it’s interesting to hear it’s not a drive issue in many cases.
    I would also never use a single drive device to backup anything I earn a living off – that’s what mirrored or RAID 5 storage is for.
    Apple’s airport and associated devices always seemed to me to be overpriced, over-designed items. It seems the latter has been the (literal) death of it.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/casestudies/detail.asp?case=therydercup
