Activity Forums Adobe After Effects Tim Burton-like twirl effect
  • Tim Burton-like twirl effect
    Posted by Anthony Miale on January 12, 2008 at 6:03 pm
    I’m trying to do some sort of warp effect on a masked layer similar to how the ground untwists under Jack Skelington’s feet in The Nightmare Before Christmas. If you are unfamiliar with the scene, the ground is spiraled underneath and bent inwards towards the character, and as he walks, it slowly unspirals to a straightish line.
    The layer is footage of an arm. I want the destination shape to be the arm as is, straightened. The base of the layer is the arms elbow and i would prefer if that did not move during the shape change. The arm is kinda thick and I don’t want the spiral to be as extreme as in the movie, but enough so that it looks like the arms initial shape is twisted in, with the hand being at the center of the spiral and then extending out to the peak.
    Any help would be greatly appreciated. Thanks!
    Anthony Miale replied 18 years, 8 months ago 3 Members · 5 Replies
  • Nicholas Toth
    January 12, 2008 at 6:34 pm
    CS3 has the puppet tool. Make the Hill/finger/arm whatever that thing is, straight in Photoshop, then import it to CS3, and distort it with the puppet tool. It’ll take some tweaking to get it perfect, but it should look good.
    Or try anime studio pro, it has an intuitive rigging system.
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Anthony Miale
    January 13, 2008 at 4:50 am
    Is there anyway to do the effect in AE 7?
  • Nicholas Toth
    January 13, 2008 at 6:42 pm
    Eh, not really. You can use certain distort filters, but it isn’t going to look as good.
    You could always break the hill into A LOT of different segments, set the anchor point to the base of the point, link all of the rotation points to a slider, and twist it like a chain. The more points the better it will look, and the more work it will be. That could look neat!
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Daniel Huisman
    January 16, 2008 at 1:52 am
    You could also try CC Bendit, depending on how much twist you need it might give the distorted effect you need.
  • Anthony Miale
    January 16, 2008 at 2:00 am
    thanks for the help. i ended up upgrading to CS3. puppet tool worked nicely
