Activity Forums Adobe Premiere Pro Tilt image on it’s center axis Premiere CC
  • Tilt image on it’s center axis Premiere CC
    Posted by Michael Lynch on February 18, 2021 at 11:56 pm
    Hopefully this is obvious. I’ve got an image imported and when I tilt from 90 to zero, the image tilt starts at the middle of the screen and bottom of the image (but lands where I want it) – I’d like the axis to be the center of the image, wherever I’ve placed it instead.
    Moved the axis point to the center of the image but that didn’t change anything. Even if it’s tilting the entire video screen wouldn’t it use the new axis point to tilt on? Fairly new to PP so forgive my convoluted description.
    Greg Janza replied 5 years, 6 months ago 4 Members · 10 Replies
  • 10 Replies
  • Jerry Wise
    February 19, 2021 at 2:10 am
    Can you attach a short video of the issue?
  • Michael Lynch
    February 19, 2021 at 5:35 pm
    Thanks. Just want it to start tilted at 90 up in the corner and then tilt to 0 to reveal.
  • Jerry Wise
    February 19, 2021 at 6:02 pm
    Hope this is what you want to see
  • Jerry Wise
    February 19, 2021 at 6:06 pm
    movie
  • Jerry Wise
    February 19, 2021 at 6:20 pm
    Well…i think my movie got lost.
  • Michael Lynch
    February 19, 2021 at 6:36 pm
    Didn’t see the movie – got lost as you said.
  • Tim Kolb
    February 19, 2021 at 11:45 pm
    The anchor point should default to the center…you shouldn’t have to move it there. I am not certain from your post what kind of move you’re talking about. Are you rotating in the Effect Controls panel…or using the Basic 3D effect to move the clip in some way?
    …or is this a transition?
  • Jerry Wise
    February 20, 2021 at 12:32 am
  • Michael Lynch
    February 20, 2021 at 1:04 am
    There you go Jerry. Something simple. I moved the text into place first and then added the effect. This time I created the text, added the tilt and it worked, so I then moved it into place and it worked as desired. Just the order of things I guess. Much appreciated.
  • Greg Janza
    February 20, 2021 at 7:54 pm
    In the future just bring it into AfterEffects. It’ll be much easier than in Premiere.
