Activity Forums Adobe After Effects Tiled fractal?
  • Tiled fractal?
    Posted by Tobbe Ottosson on November 22, 2008 at 12:24 pm
    I have already managed to make a Fractal noise smooth looping animation.
    But I need it to be tileable too(smooth edge to edge), is that possible?
    (it’s possible in photoshop with 128*128 cloud filter.. but you can’t animate it there. :C)
    Jens Enqvist replied 17 years, 6 months ago 2 Members · 1 Reply
  • Jens Enqvist
    November 22, 2008 at 11:24 pm
    Fractal Noise does not support spatial tiling. Some workarounds are available such as CC Repetile but that is not the same as a truly spatially tileable fractal such as the PS cloud filter. Not sure if the new CS4 fractal effect supports spatial tiling.
    Try using CC Repetile and see if that is sufficient for your needs.
    On a more technical level, supporting spatial tiling is not difficult. However, it would make scaling and subscaling inanimateable.
