Activity › Forums › Adobe After Effects › Tile a layer or object in a layer?
  • Tile a layer or object in a layer?
    Posted by Brian Lynn on August 7, 2007 at 5:56 pm
    I know I’ve done this before, its just been so long since I’ve needed to use the tool I’ve forgotten where it is!
    I need to take a graphics strip 100x400px and simply loop it edge to edge so I can continually scroll it across the screen, or in this case, vertical slightly up the 3D slope…
    I thought it was Motion Tile… but if I set ‘Autoscroll – Horizontal (or vertical) I get this message:
    Bad Arguement: Couldn’t find effect named “Autoscroll – Horizontal’ Expression disabled.
    Well I thought this was it. And maybe it is, and I am just doing something wrong or I’ve forgotten something really important…
    Thanks for any help!
    Brian
    Brian Lynn replied 19 years, 1 month ago 2 Members · 2 Replies
  • Kevin Camp
    August 7, 2007 at 7:25 pm
    apply the motion tile effect via the effects presets, rather than from the preset pulldown from within the motion tile effect panel.
    the preset adds a slider control called “autoscroll – vertical” without that the expression is broken. (you could add you own slider and name it autoscrole – vertical i suppose…)
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Brian Lynn
    August 7, 2007 at 9:22 pm
    Oh, I could smack myself. I knew there was something I was forgetting!
    Thanks so much!
