Activity Forums Adobe Premiere Pro tilda full screen
  • tilda full screen
    Posted by Neil Christian on August 13, 2014 at 2:12 pm
    Hi I am using premier pro and have lost my second monitor for a while so was searching to see what the method of viewing in full screen is. I found a lot of stuff all suggesting g i highlight the viewer and use the tilda key or the control and tilda key but non of this done anything for me. It’s Premier Pro CC. Dose anyone know how I should go about this or what I might be doing wrong?
    Neil Christian replied 12 years, 1 month ago 4 Members · 6 Replies
  • Yair Bartal
    August 13, 2014 at 2:21 pm
    If you’ve pressed the tilde key with the shift key, try without the shift key.
    This should work.
  • Neil Christian
    August 13, 2014 at 2:42 pm
    unfortunately not. not tilda , tilda and shift , tilda and control. All do nothing. I just tried a different key board and same problem.
  • Andy Edwards
    August 13, 2014 at 2:45 pm
    Check your keyboard shortcuts to see if the tilda key has actually been assigned to maximize active frame to full screen.
    Andy Edwards
  • Neil Christian
    August 13, 2014 at 2:49 pm
    Ok I found it . It’s apostrophe/@ key next to the tilda key. For anyone who ends up here in the future that’s what works on my Windows 8.1 PC and Premier Pro CC.
  • Ann Bens
    August 13, 2014 at 5:28 pm
    Everybody calls it the tilde key but in fact its the grave key (`)
    Ctr+` will give you full screen playback on the first monitor.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Neil Christian
    August 13, 2014 at 7:58 pm
    On both my key boards the grave key is situated where people keep describing the tilda key, top left side above the Tab and below the escape key. The key with the tilda symbol also has the hash mark and is situated middle left next to the return key.
    But both these keys do nothing in Premier Pro CC for me. The full screen is the apostrophe/@ key (‘@). This is why I could not find it. It’s very odd that I seem to have a different key for this. I found it by looking under the window menu and the third option down is “full frame” which I now know is full screen and next to it it has the keyboard short cut, (Shift+’)
