Activity Forums Adobe After Effects Tight deadline! Problems with Particular Project
  • Tight deadline! Problems with Particular Project
    Posted by Reuben Fink on October 4, 2013 at 7:34 pm
    I already posted a thread regarding how to create a ribbon with photos and particular.
    https://forums.creativecow.net/thread/2/1042303
    Sorry to post again but I’m on a tight deadline and haven heard a fix for this yet.
    At my first pass I got the motion and the photo spacing correct based on a precomp of about 50 images, but then realized I was getting images out of order and duplicates. I am using “Current Frame – Freeze. Well I learned that to fix this I would need to make the particles/sec the same number as my image precomp framerate which is 30. This did put them in proper order with no dupes. The problem is that when the particle emitter is going the proper speed so we can actually discern the photos, it’s too slow for particular to keep them spaced properly & the photos stack on top of each other as seen in the pic below.
    https://www.dropbox.com/s/q5z1rmy1qs5a7b2/ribbon%20issue.jpg
    Is there a way to change the spacing without changing the speed of the animation. Or any workarounds. Much thanks if you can help me.
    OSX 10.8.4
    Equipment: 2.8 ghz 8 core Intal Mac Pro 3,1 Early 2008, 20 gig of ram
    Aps: CS6 Production Premium, FCP Suite, Avid Media Composer
    Reuben Fink replied 12 years, 8 months ago 6 Members · 12 Replies
  • 12 Replies
  • Anders Hattne
    October 4, 2013 at 7:57 pm
    Don’t know about particular and getting that right, but couldn’t you get this shape done with Freeform?
    http://www.ardillamedia.com
  • Erik Waluska
    October 4, 2013 at 9:20 pm
    Zaxwerks Serpentine and 3D Warps plug-ins would probably work for this as well and they’re about half the price.
    I have a free after effects filmstrip template on my site that would probably be useful as well.
    Erik Waluska
    EAWmedia
  • Ridley Walker
    October 4, 2013 at 9:40 pm
    Would a simple “Follow the leader” animation suffice?
    6603_followtheleader.aep.zip
    The Layer labeled “Leader” has a slider control that adjusts the offset.
  • Reuben Fink
    October 5, 2013 at 12:07 am
    These are all really good suggestions. But I was hoping for a fix with Particular since several comps have already been setup already. They are basically done. I was hoping to just find some kind of fix with particular to adjust the offset like in the follow the leader example. BTW I did start the project with the follow the leader expression and it seemed like it would work but once I had to do it with over 40 images it slowed down to a crawl. It was very tedious to work with. Now I did mess with freeform for the first time today and I gotta say that might have been the route to go. Very straight forward. Though I feel if I can figure this out there are some advantages to the look and feel of doing it with particles. I’ll take a look at Zaxwerks. But in the meantime if anyone can figure out, maybe with an expression which is not my forte, how to change the offset with particular, that would rock.
    Thanks for all the info.
    OSX 10.8.4
  • Ridley Walker
    October 5, 2013 at 12:36 am
    [Reuben Fink] “Is there a way to change the spacing without changing the speed of the animation.”
    What if you just reduce the size of the particles and then adjust the Z offset W under World Transform?
  • Anders Hattne
    October 5, 2013 at 8:34 am
    Freeform is included since CS5, and according to the stats, man in question has cs6.
  • Reuben Fink
    October 6, 2013 at 10:20 pm
    Sorry but Freeform is not included in CS6 or CC. They stopped bundling it in CS6. So purchase is the only option apparently.
    https://blogs.adobe.com/aftereffects/2012/05/freeform-and-after-effects-cs6.html
    OSX 10.8.4
  • Chris Bobotis
    October 6, 2013 at 10:53 pm
    Reuben is right. FreeForm V2 (only $99.00) replaces Digieffects FreeForm that was bundled with CS5. FreeForm V2 is up to 10 times faster and will open all files created with the bundled version. See: https://www.mettle.com/freeform-v2/
    Cheers,
    Chris
    mettle.com
  • Cassius Marques
    October 7, 2013 at 5:04 pm
    maybe this will come a little late but… If you want to double the space between the photos(that are actually particles) just cut in half the emission number!
  • Reuben Fink
    October 15, 2013 at 12:34 am
    Deadline is passed and it looks like freeform was the solution for now. But I’m so determined to find a solution using particular so here I am again following up. Cassius your suggestion would work if it didn’t matter what order the photos emitted. The problem is I have to stick with the emission number of 30 since that’s my frame rate, to keep all images in the proper order and to make sure I don’t have any duplicates. In the project you sent me you added this expression:
    t=thisComp.layer(“Draw Path”).inPoint;
    thisComp.layer(“Draw Path”).position.valueAtTime(t);
    Which made the particles follow the leader. Is there anything else we could add to the expression to delay the trailing particles so they don’t all stack on top of each other? Basically create an offset for each particle that’s following?
    If it’s impossible with an expression then I will drop this obsession ;).
    OSX 10.8.4
