  • Posted by Joe Zabrosky on October 2, 2014 at 4:12 am
    Have a movie of which someone from TBN watched and said the audio was understandable but it wasn’t TIGHT.
    We recorded the audio chiefly with a boom mic following actors and an ambient mic at a central point in each scene not on the actors so that we could have a realistic sound. Majority of scenes were interiors. When i told the guy from TBN this he said that could be the problem in that the ambient mic was causing a bit of an echo lending to it not having a tight overall sound on the dialogue. He suggested getting rid of the ambient channel.
    My question? What would be my best bet to create as tight a sound as possible to put on that second channel once i take the ambient recording out?
    Thanks for your help! joe
    joseph zabrosky
    Joe Zabrosky replied 11 years, 11 months ago 3 Members · 4 Replies
  • Mark Suszko
    October 2, 2014 at 2:10 pm
    “Tight” , as your associate calls it, is a very subjective term. There’s no meter or scale for it. But if you want to increase the clarity of the audio, you might play with compression of frequencies in the range of human hearing. That “full” sounding DJ voice on the radio comes out of a box, a box with gates and compressors that emphasize certain frequencies. You have access to those same effects in post. Experiment with that, and with parametric EQ to drop out some of the ambience/room tone.
  • Joe Zabrosky
    October 2, 2014 at 6:55 pm
    Thanks for both of your responses. So, if it sounds more clearly with the ambient track OFF are you suggesting to use only one track for dialogue or would it be wise to fill that vacant track with something that would bring more clarity and dynamic to the mix? Thanks, joe
    joseph zabrosky
  • Shane Ross
    October 2, 2014 at 10:27 pm
    I suggest not killing it, but lowering the ambience. Although really, the dialog that took place in that location should have enough ambience. I’ve never heard of laying down separate ambience or “room tone” in a scene where the dialog is continuous. I’ve used that to fill gaps or cover other sounds that happen on set.
    But then again, I also don’t do my own final audio mix…I have professionals do it.
    Shane
    Little Frog Post
  • Joe Zabrosky
    October 8, 2014 at 3:05 pm
    I think your both right on that. The audio guy suggested it, but it lends to sound not being tight so i’m bringing the ambient down, panning it to center, panning boom mic to center and bringing volume up. It makes a big difference. Thanks
    joseph zabrosky
