Activity Forums Blackmagic Design Tiger issues
  • Tiger issues
    Posted by Tristan Nieto on May 31, 2005 at 6:12 am
    Getting major playback issues – by major i mean sound and vision scrambled into little bits and chewed into a fine fuzzy paste – using Decklink Extreme, FCP 4.5 and OSX 10.4.
    I’ve been to the decklink site which says use driver 4.8 for OSX 10.3 and FCP 4.5 and driver 5.0 for OSX 10.4 and FCP 5.
    Not sure which driver to use, not sure if it is a driver issue at all.
    Any thoughts?
    G5 Dual 2.3Ghz
    4.0GB Ram
    OSX 10.1
    FCP 4.5
    Decklink SD Extreme
    Dalen Quaice replied 21 years, 3 months ago 2 Members · 1 Reply
  • Dalen Quaice
    May 31, 2005 at 3:28 pm
    Likely the problem is that there is not a FCP 4.5-Tiger blackmagic driver, so your configuration is not supported. If you are running Tiger, you need to upgrade to FCP 5. If you can’t do that, then consider reinstalling 10.3.8
