Activity Forums Apple Motion Tiger: Audio is now hosed
  • Tiger: Audio is now hosed
    Posted by Scot Walker on May 2, 2005 at 6:15 pm
    I have an existing project with a VO track and it now doesn’t play since I installed Tiger.
    Anyone else upgrade to Tiger (unwisely) and experiencing this?
    Scot Walker replied 21 years, 4 months ago 1 Member · 1 Reply
  • Scot Walker
    May 2, 2005 at 6:32 pm
    https://docs.info.apple.com/article.html?artnum=301198
    Tiger may change your sound output to 33000.0 Hz when you upgrade. If it does, existing projects that were created with 44.1 Hz will not play the audio.
    To fix, launch Audio MIDI Setup, which is in the Utilities folder. Look over at the right where it says Audio Output and make sure your format is set to whatever you had before (44.1 Hz is the default, I believe).
