Activity › Forums › Adobe After Effects › tiffen dtf/dfx, version conflict
  • tiffen dtf/dfx, version conflict
    Posted by Juan Perez on September 1, 2010 at 9:36 am
    hello! i edited a short feature in year 2005, using several dft/dfx effects under after effects. now i need to re-edit it, and have the present tiffen dft dfx suite (v. 2.0.2.1) installed under ae cs4. the fact is ae cs4 doesn’t recognize any of those dfx effects that i used in 2005 (i’m talking about: Diffusion, ND Grad, Selective Color Correct, Gels and Color Grad); it says they`re “non existing”.
    some facts: 1) the present suite has all those effects, even with the same names (exceptions: “color grad” is now “color-grad”, and “nd grad” is now “nd-grad”). 2) if i manually rebuild the settings that i used in 2005 in one of these present effects, the visual results are identical (even when the present version of the effect, in some cases, offers one or two new parameters, which i obviously don’t touch). 3) i don’t have anymore the original DFT/dfx suite, and i can’t even remember which version it was (that whole computer was stoled in 2006). 4) this project has hundreds of instances of the mentioned effects, and it would be very embarrasing to manually rebuild all of them.
    my question: is it possible to “tell” AE to “forget” the old dft/dfx effects and use, instead, the corresponding present v.2.0.2.1 ones with the same settings? thank you very much in advance!
    David Johnson replied 16 years ago 3 Members · 2 Replies
  • Walter Soyka
    September 1, 2010 at 4:14 pm
    [juan perez] “my question: is it possible to “tell” AE to “forget” the old dft/dfx effects and use, instead, the corresponding present v.2.0.2.1 ones with the same settings? thank you very much in advance!”
    I don’t believe that this is possible to do. I’d contact Tiffen for support. Most other plugin developers are very careful to make sure that older projects will open properly.
    Walter Soyka
  • David Johnson
    September 2, 2010 at 3:26 pm
    I’m with Walter on both counts … “I don’t believe that this is possible to do” and “I’d contact Tiffen for support”.
    The issue is that the Tiffen DFX bundle originated with a different company (Digital Film Tools) and was somewhat re-written during the transition. That’s typically the case when plugins are sold from one developer to another, which happens frequently and is the reason it’s always best to keep copies of old plugin versions you’ve used extensively. It’s generally far faster to just install an old plugin version to tweak an old project than it is to try to conform a new version to the old version settings.
    You can probably find the old version available for download somewhere (maybe even DFT’s website). I have copies of all my old plugins going back to the early 90s so, if you can’t find it and you’ll mention exactly which version you need, I could probably send it to you (without my serial number, of course … you’ll have to use your own).
