Activity Forums Apple Final Cut Pro Legacy tiff sequence into SD anamophic
  • tiff sequence into SD anamophic
    Posted by Michael Gissing on October 16, 2007 at 12:12 am
    Although I requested a QT file, I was given a tiff sequence (1024 x 576) for a PAL SD project by the graphic designer. I loaded the files in FCP but the default duration was 10 seconds not one frame. With client hovering, I thought easier to import into Motion and then export a QT file.
    Imported the tiffs into Motion but they were cut off at the edge (ie: not scaling to the SD anamorphic project that I had created). With client hovering I said I would fix the problem later. I prefer to work out what is happening with Motion as I would rather a single clip to grade. I am hoping that Motion can import 1024 x 576 and scale to anamorphic, rather than just cut the edges off. I have Photoshop and considered rescaling all the tiffs but I am sure there is an easier way.
    I am sure one of the Motion/ FCP wise ones here could tell me what I set wrong while I look through the manual. Thanks
    FCS2 (FCP 6.0.1 Motion 3)
    Alan Lacey
    replied 18 years, 11 months ago
    5 Members · 6 Replies
  • Walter Biscardi
    October 16, 2007 at 12:17 am
    [Michael G] “I loaded the files in FCP but the default duration was 10 seconds not one frame.”
    Just go into your preferences and change this to one frame, re-import to FCP. FCP should make it anamorphic.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Shane Ross
    October 16, 2007 at 12:22 am
    YOu can change the default import time to one frame you know…
    USER-PREFERENCES>EDITING….STILL/FREEZE DURATION. Change it to 1 frame.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Michael Gissing
    October 16, 2007 at 12:26 am
    Thanks Walter. That worked but I remain curious about Motion which is not a program that I use often.
  • Arnie Schlissel
    October 16, 2007 at 2:06 am
    Set up a new motion project at 25 fps, with a frame size of 1024X576, square pixels. Then import the tiff sequence. Set the output in Motion to PAL anamorphic, with whatever video settings you’d normally use.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Michael Gissing
    October 16, 2007 at 2:15 am
    Thanks Arnie. That did the trick. I was making the mistake of setting the Motion sequence to PAL SD anamorphic, not using a custom setup.
    I was looking for a way to rescale the tiffs after import.
  • Alan Lacey
    October 16, 2007 at 11:38 am
    Yes but then FCP takes an AGE to open as it has to check all 10,000 frames of the bitmap sequences. FCP is the only NLE I know that won’t import frame sequences.
    The workaround is to use QTpro to convert to a QTmov – thereby doubling your disk usage.
    Alan
