Activity › Forums › Adobe After Effects › Tiff sequence flicker after pull in to fire?
  • Tiff sequence flicker after pull in to fire?
    Posted by Deadittex on March 8, 2006 at 4:45 pm
    Okay so here is the sitchuation, I will try to be as specific as I can. I am trying to export a credit roll from an after effects comp and bring it into discreet logic fire version 5.1.2. Whats happening is that we have a flicker which almost apears as a repeated frame stagger, but isn’t as we see no indication of this on the fire action window.
    Okay so we created a project with a 24fps setting amd a 1080 X 1920 HD comp size, and an HDTV color setting, we pulled in a Illistarter file with the text and lay out, then we re-positioned it through time finally outputting as a Tiff sequance. Sent it through our network into fire, and pulled it in.
    Now the comp is about 3 minutes in lenghth and we usually have around 3500 tiff frames at the end of the export which to me seems about acurate?
    We have tryed fram blending to no avail. What can we do to get rid of the stagger that is happening once fire prossesses the tiffsequance back to motion?
    Deadittex replied 20 years, 6 months ago 7,234 Members · 1 Reply
  • Deadittex
    March 8, 2006 at 11:03 pm
    Oh come on, HELP, Really… I need it.. I didn’t stump you did I ??
