Activity › Forums › Apple Final Cut Pro Legacy › tiff into FCP
tiff into FCP
Posted by Klaus on July 15, 2005 at 4:50 amHow do you import a tiff sequence into FCP?
Joe Paolo replied 21 years, 1 month ago 3 Members · 3 Replies -
Jerry Hofmann
July 15, 2005 at 4:56 amChange your still frame duration to one frame in the user prefs.
import a folder with all those numbered tiffs in it…
Drag all tiffs to a sequence (numbering important so you can get them in the right order), then export this as a self contained QT movie… import that file, and use it as a clip!
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Joe Paolo
July 15, 2005 at 10:50 pmOr “Open image sequence” in QT pro and export as needed. I find that way easier.
joe
