Activity Forums Adobe After Effects TIE DYE
  • Steve Roberts
    November 15, 2007 at 7:21 pm
    If I recall, tie-dyed images looked like rough, thick rings.
    To get the ring, I might make a long thick, scraggly line, then apply Polar coordinates (rect>polar) to make the ring. As for the line, I could scribble something up/down, slowly moving across, or maybe make a long comp, apply Fractal noise, with maybe directional blur(vertical).
    To get motion, I might animate the fractal noise, and/or animate the line up or down inside its comp, or animate the scale of the ring. Transfer modes should look cool – vivid light?
    For colour, I’d use Colrama and experiment. Make copies of the rings at various sizes and positions.
    Anybody else?
  • Thomas Mcmurry
    November 15, 2007 at 7:42 pm
    thanks for the quick response!
    I’ll give it a go and see what happens.
    thanks again.
  • David Bogie
    November 15, 2007 at 9:15 pm
    Oh, yeah, but I’d say mandelbrot or julia sets from Fractals, not fractal noise. then use tiling or kaleidescope filters.
    This will NOT emulate real tie dye (I’ve done lots of this stuff with various fabrics and techniques), it will always look fake. You need to go buy some tie dyed t-shirts and scan the fabrics. You might be able to find stock photos of tie dyed fabrics.
    bogiesan
