Activity Forums Blackmagic Design Thunderbolt port on BMD Cinema Camera
  • Thunderbolt port on BMD Cinema Camera
    Posted by Nigel Thompson on April 28, 2012 at 2:56 am
    Does the thunderbolt port on the camera support video output or is the port just for data transfer ie. files from SSD to Raid storage for editing or whatever ?
    Nigel
    High End, Production & Post Production
    in the Caribbean
    http://www.bistt.com
    Deleted User replied 14 years, 4 months ago 3 Members · 2 Replies
  • Clay Couch
    April 29, 2012 at 12:55 pm
    Hey this is from specs, I hope this helps :).
    SDI Video Output 1 x 10-bit HD-SDI 4:2:2 with choice of Film or Video Dynamic Range
    Analog Audio Input 2 x 1/4” jacks for professional balanced analog audio, switchable between mic and line levels.
    Analog Audio Output 1 x 3.5mm stereo headphone output
    SDI Audio Output 4 channels in HD-SDI
    Remote Control 1 x 2.5mm LANC for Rec Start/Stop, Iris Control and Focus Control
    Computer Interface Thunderbolt port for capture of RAW video and audio.
    USB 2.0 mini B port for software updates and configuration.
    External Power 12V-30V DC port for external battery power or use included 12V AC adapter.
  • Deleted User
    April 30, 2012 at 2:07 pm
    It appears that at least initially the TB port on the BmCC is intended for use with a TB-equipped computer running the included UltraScope software.
    If BmD implements them the BmCC’s TB port may have other uses later, or perhaps 3rd parties may be able to provide additional support. But if I understand what John Brawley is stating in the following thread, it’s for UltraScope support initially, and maybe more capability down the road. See:
    https://www.bmcuser.com/showthread.php?128-Updates-on-some-features
    As for transferring files from the BmCC’s SSD to other devices, it appears the primary method will be to temporarily insert the SSD drive into a drive caddie/cradle connected to a computer which in turn is connected to internal or external HDD or RAID storage. Drive caddies are available from a variety of vendors, as are interfaces to connect to them (fastest to slowest: SATA, Firewire 800/400, USB 2/3), and caddies are relatively inexpensive.
    Myself I’m looking into acquiring a dual SATA port Express34/PCMCIA adapter card for use with my non-TB MacBook Pro 17″ i7 laptop, which should allow me to connect an external SATA caddie and external HDD for fast file transfers from the SSD drive for editing (from the HDD) and backups (to multiple HDDs). YMMV.
    https://www.peterdv.com
