Activity Forums Apple OS X Thunderbolt Networking suddenly not working, USB network & WIFI fine
  • Thunderbolt Networking suddenly not working, USB network & WIFI fine
    Posted by Al Bergstein on February 26, 2016 at 4:52 pm
    Anyone experienced a sudden loss of the ability for their Mac to not be able to run TB networking?
    It was working yesterday on home network. Brought it to hotel and received 10Mbps non filtered feed. Will not see the network. Tried rebooting. Tried three different TB>Ethernet adapaters, and both ports. A similar macbook sitting right next to it can see the network and be assigned an IP address fine. I’ve turned off the firewall(not something I want to do on a live feed), and many other ideas, all to no avail. Luckily the USB>Ethernet works fine on the USB 3 port. Thoughts???? Ideas?
    The thunderbolt ports work fine because I have a device I need to hook up and when hooked up the device communicates fine to the machine. Obviously the ports are ok, and I have tried disconnecting the device, and rebooting. The ports should work fine but… ??? ?
    This setup has worked fine as recently as Weds. It is now Friday.
    MacBook Pro
    Model Identifier: MacBookPro11,3
    Processor Name: Intel Core i7
    Processor Speed: 2.5 GHz
    Number of Processors: 1
    Total Number of Cores: 4
    L2 Cache (per Core): 256 KB
    L3 Cache: 6 MB
    Memory: 16 GB
    Al
    Al Bergstein replied 10 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
