Activity Forums Apple Final Cut Pro Thunderbolt 4 dock for better speed
  • Thunderbolt 4 dock for better speed
    Posted by David Mayer on January 14, 2025 at 2:51 pm
    I edit on a 2024, M4 chip mac mini, using Samsung T7 Touch SSD drives.
    In order to take full advantage of the speed of the computer, I am thinking about
    buying the CalDigit Thunderbolt 4 Pro Dock from the Apple Store. But then I would probably also want faster edit drives. Looking for suggestions.
    Devrim Akteke replied 1 year, 8 months ago 3 Members · 2 Replies
    January 14, 2025 at 3:31 pm
    Hey David,
    Back in the day for my Mac Mini M1 I added a OWC Thunderbolt 4 hub.
    Works great with Samsung T7 and T9 SSD drives.
    https://www.owc.com/solutions/thunderbolt-hub
    But you may consider Thunderbolt 5, which is being rolled out, and should hopefully be backward compatible (Do check before purchasing).
    https://www.owc.com/solutions/thunderbolt-5
  • Devrim Akteke
    January 14, 2025 at 3:38 pm
    Most SSDs are pretty fast these days. They have a speed of more than 2000MB per second which is enough almost for any work you need. What is better than an SSD, is SSD RAID, a bunch of SSDs working together as one. You can check OWC, Sandisk, and Glyph for these raids.
