Activity Forums Broadcasting Thunder Browse and Lightning issue
  • Thunder Browse and Lightning issue
    Posted by James Hoppe on May 25, 2010 at 5:20 pm
    We are having an issue with our Thunder Browse and Lightning systems. The Thunder can’t overwrite an existing sequence on the Lightning system, even if that sequence is NOT open or even if the Lightning software is closed entirely. The software versions are the same on both boxes. Lightning is running on NT 4.0 (with all the proper SPs installed) and the other system is XP Pro-SP3 with the latest security patches installed. Write permissions are set properly within the OS, the Thunder user can do a “save-as” and write the sequence to the Lightning’s shared drive.
    James Hoppe
    WILX-TV
    Engineering
    James Hoppe replied 16 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
