Activity › Forums › Square Box CatDV › Thumbnail shows up but not the original movie
  • Thumbnail shows up but not the original movie
    Posted by Chuck Johnson on June 17, 2012 at 8:45 pm
    Hi All,
    Here’s a strange one…any ideas on fixing this would be appreciated…
    This is a new installation of Server 6.6 on a new Mac mini server and Pegasus RAID system.
    Have installed the Calibrated codecs.
    I click on a P2 MXF file and when I do that I see Calibrated sees it by the Summary/Format information. However, when I drag it over to be cataloged, the Calibrated goes away and Class 50 72-/59.94P shows up instead. When I click on the the clip in CatDV, a white screen shows up instead of the video clip. Usually, when one sees a white screen that means a codec is missing…I reinstalled Calibrated and still no difference.
    Any other things I can try?
    Chuck
    Chuck Johnson replied 14 years, 3 months ago 2 Members · 3 Replies
  • Chuck Johnson
    June 17, 2012 at 8:53 pm
    Here’s some information that might help explain what is going on…
    6/14/12 4:36:23.136 PM ControlPanel CGContextGetCTM: invalid context 0x0
    6/14/12 4:36:23.137 PM ControlPanel CGContextSetBaseCTM: invalid context 0x0
    6/14/12 4:36:23.137 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 16:36:23 catdv.bbwcg.local ControlPanel[602] : CGContextGetCTM: invalid context 0x0
    6/14/12 4:36:23.137 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 16:36:23 catdv.bbwcg.local ControlPanel[602] : CGContextSetBaseCTM: invalid context 0x0
    6/14/12 4:36:23.137 PM ControlPanel CGContextGetCTM: invalid context 0x0
    6/14/12 4:36:45.101 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 4:53:38.971 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:39.165 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 4:53:39.377 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:39.412 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 4:53:39.495 PM xscertd Starting xscertd/1.0.0 (MacOS X Server)
    6/14/12 4:53:39.498 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:39.501 PM xscertd Received connection from 10.0.1.22:53032
    6/14/12 4:53:39.501 PM xscertd Received request from 10.0.1.22:53032
    6/14/12 4:53:39.501 PM xscertd Processing request from 10.0.1.22:53032 of /rfc2585/IntermediateCA_CA…
    6/14/12 4:53:39.504 PM sandboxd ([1496]) xscertd(1496) deny job-creation
    6/14/12 4:53:39.517 PM xscertd-helper Starting xscertd-helper/1.0.0 (MacOS X Server)
    6/14/12 4:53:39.537 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 4:53:39.611 PM xscertd Returning response with code 200 to 10.0.1.22:53032
    6/14/12 4:53:39.681 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:39.715 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 4:53:39.804 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:39.972 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 4:53:40.105 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 4:53:40.140 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 5:49:35.135 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 5:50:45.233 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 5:50:45.276 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 5:50:45.443 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 5:51:45.232 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 5:51:55.306 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 5:52:05.320 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 6:23:16.090 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:16.291 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:23:16.433 PM xscertd Starting xscertd/1.0.0 (MacOS X Server)
    6/14/12 6:23:16.438 PM xscertd Received connection from 10.0.1.22:54643
    6/14/12 6:23:16.438 PM xscertd Received request from 10.0.1.22:54643
    6/14/12 6:23:16.438 PM xscertd Processing request from 10.0.1.22:54643 of /rfc2585/IntermediateCA_CA…
    6/14/12 6:23:16.441 PM sandboxd ([2132]) xscertd(2132) deny job-creation
    6/14/12 6:23:16.454 PM xscertd-helper Starting xscertd-helper/1.0.0 (MacOS X Server)
    6/14/12 6:23:16.498 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:16.532 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:23:16.546 PM xscertd Returning response with code 200 to 10.0.1.22:54643
    6/14/12 6:23:16.606 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:16.784 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:23:16.918 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:16.954 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:23:17.032 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:17.066 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:23:17.134 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:23:17.167 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:24:23.223 PM xscertd Received connection from 10.0.1.22:54665
    6/14/12 6:24:23.224 PM xscertd Received request from 10.0.1.22:54665
    6/14/12 6:24:23.224 PM xscertd Processing request from 10.0.1.22:54665 of /rfc2585/IntermediateCA_CA…
    6/14/12 6:24:23.231 PM xscertd Returning response with code 200 to 10.0.1.22:54665
    6/14/12 6:25:50.049 PM xscertd Received connection from 10.0.1.22:54693
    6/14/12 6:25:50.050 PM xscertd Received request from 10.0.1.22:54693
    6/14/12 6:25:50.050 PM xscertd Processing request from 10.0.1.22:54693 of /rfc2585/IntermediateCA_CA…
    6/14/12 6:25:50.056 PM xscertd Returning response with code 200 to 10.0.1.22:54693
    6/14/12 6:44:35.228 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 6:45:45.326 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 6:45:45.368 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 6:45:45.532 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 6:46:45.327 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 7:51:45.503 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 7:51:55.517 PM servermgrd servermgr_accounts: got error 2100 trying to auth to local LDAP node
    6/14/12 8:16:07.977 PM com.apple.SecurityServer PAM: Unable to authenticate.
    6/14/12 8:16:07.977 PM com.apple.SecurityServer checkpw() returned -2; failed to authenticate user cjohnson (uid 501).
    6/14/12 8:16:08.022 PM com.apple.SecurityServer PAM: Unable to authenticate.
    6/14/12 8:16:08.023 PM com.apple.SecurityServer checkpw() returned -2; failed to authenticate user cjohnson (uid 501).
    6/14/12 8:16:08.023 PM com.apple.SecurityServer Failed to authorize right ‘system.login.tty’ by client ‘/Library/Application Support/LogMeIn/bin/LogMeIn.app’ [111] for authorization created by ‘/Library/Application Support/LogMeIn/bin/LogMeIn.app’ [111]
    6/14/12 8:16:17.230 PM LogMeInGUI String:GUIMSG:USERLOGON
    6/14/12 8:16:24.224 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – SessionManager – DisplayServer init
    6/14/12 8:16:24.224 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSHM-LMI_SERVER – Creating shared memory
    6/14/12 8:16:24.224 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSMFRS – Creating semaphores: LMI_SERVER_start and LMI_SERVER_end
    6/14/12 8:16:24.224 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSHM-LMI_CALLBACK – Creating shared memory
    6/14/12 8:16:24.224 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSMFRS – Creating semaphores: LMI_CALLBACK_start and LMI_CALLBACK_end
    6/14/12 8:16:24.225 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – Graphics – Initializing Display server
    6/14/12 8:16:24.225 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSHM-LMI_SERVER – Shared memory created (16777208 bytes)
    6/14/12 8:16:24.225 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.224 – Debug – LMIGUIAgent – IPCSHM-LMI_CALLBACK – Shared memory created (1048568 bytes)
    6/14/12 8:16:24.228 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.227 – Info – LMIGUIAgent – Graphics – Initialized for display 188773497 detected OSX version 10.7.4 monitor present using Quartz
    6/14/12 8:16:24.229 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.228 – Debug – LMIGUIAgent – Graphics – isOnLoginScreen: no
    6/14/12 8:16:24.229 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.228 – Debug – LMIGUIAgent – Graphics – Sending SERVERINIT
    6/14/12 8:16:24.229 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.228 – Debug – LMIGUIAgent – Graphics – Sending DISPLAYSCHANGED
    6/14/12 8:16:24.229 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.229 – Debug – LMIGUIAgent – Graphics – Display server initialized
    6/14/12 8:16:24.229 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.229 – Debug – LMIGUIAgent – GUIAgent – DisplayServerStarted.Sent[325]
    6/14/12 8:16:24.325 PM LogMeInGUI String:RC:ACTIVE
    6/14/12 8:16:24.325 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.325 – Debug – LMIGUIAgent – SessionManager – Got DisplayDialog 0
    6/14/12 8:16:24.325 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.325 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – initWithWindow
    6/14/12 8:16:24.325 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.325 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification LogMeIn – Remote Session
    6/14/12 8:16:24.327 PM LogMeInGUI remoteControl:ACTIVE
    6/14/12 8:16:24.331 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.331 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification – height 65 textSize: 266 35 text: This computer is being remote controlled by cjohnson from mail.bbwcg.com.
    6/14/12 8:16:24.351 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.350 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 8:16:24.354 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.353 – Debug – LMIGUIAgent – Timer – Stopping timer
    6/14/12 8:16:24.354 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.353 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 8:16:24.360 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.360 – Debug – LMIGUIAgent – Graphics – Display is asleep in copyToBitmapUsingQuartz.
    6/14/12 8:16:24.360 PM com.logmein.logmeinguiagent 2012-06-14 20:16:24.360 – Debug – LMIGUIAgent – Display – Waking up the display.
    6/14/12 8:17:14.756 PM ControlPanel CGContextGetCTM: invalid context 0x0
    6/14/12 8:17:14.756 PM ControlPanel CGContextSetBaseCTM: invalid context 0x0
    6/14/12 8:17:14.756 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 20:17:14 catdv.bbwcg.local ControlPanel[602] : CGContextGetCTM: invalid context 0x0
    6/14/12 8:17:14.756 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 20:17:14 catdv.bbwcg.local ControlPanel[602] : CGContextSetBaseCTM: invalid context 0x0
    6/14/12 8:17:27.769 PM ControlPanel CGContextGetCTM: invalid context 0x0
    6/14/12 8:17:27.769 PM ControlPanel CGContextSetBaseCTM: invalid context 0x0
    6/14/12 8:17:27.769 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 20:17:27 catdv.bbwcg.local ControlPanel[602] : CGContextGetCTM: invalid context 0x0
    6/14/12 8:17:27.769 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Jun 14 20:17:27 catdv.bbwcg.local ControlPanel[602] : CGContextSetBaseCTM: invalid context 0x0
    6/14/12 8:17:53.522 PM com.apple.SecurityServer Session 100006 created
    6/14/12 8:18:56.749 PM firefox -_scrollPhase is deprecated for NSScrollWheel. Please use -momentumPhase.
    6/14/12 8:32:08.319 PM DiskImages UI Agent *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
    6/14/12 8:32:08.319 PM [0x0-0x42042].com.apple.DiskImageMounter 2012-06-14 20:32:08.318 DiskImages UI Agent[3096:707] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
    6/14/12 8:32:16.334 PM Installer @(#)PROGRAM:Install PROJECT:Install-690
    6/14/12 8:32:16.334 PM Installer @(#)PROGRAM:Installer PROJECT:Installer-537
    6/14/12 8:32:16.334 PM Installer Hardware: Macmini5,3 @ 2.00 GHz (x 8), 8192 MB RAM
    6/14/12 8:32:16.335 PM Installer Running OS Build: Mac OS X 10.7.4 (11E53)
    6/14/12 8:32:16.428 PM Installer Calibrated{Q} MXF Import Installation Log
    6/14/12 8:32:16.428 PM Installer Opened from: /Volumes/Calibrated{Q} MXF Import/MXF Import Installer-v2.2.0.pkg
    6/14/12 8:32:44.375 PM Installer InstallerStatusNotifications plugin loaded
    6/14/12 8:32:47.606 PM Installer ================================================================================
    6/14/12 8:32:47.606 PM Installer User picked Custom Install
    6/14/12 8:32:47.606 PM Installer Choices selected for installation:
    6/14/12 8:32:47.606 PM Installer Install: “Calibrated{Q} MXF Import”
    6/14/12 8:32:47.607 PM Installer Install: “Calibrated{Q} MXF Import”
    6/14/12 8:32:47.607 PM Installer ================================================================================
    6/14/12 8:33:03.521 PM Installer ================================================================================
    6/14/12 8:33:03.521 PM Installer User picked Standard Install
    6/14/12 8:33:03.521 PM Installer Choices selected for installation:
    6/14/12 8:33:03.521 PM Installer Install: “Calibrated{Q} MXF Import”
    6/14/12 8:33:03.522 PM Installer Install: “Calibrated{Q} MXF Import”
    6/14/12 8:33:03.522 PM Installer ================================================================================
    6/14/12 8:33:03.563 PM Installer Configuring volume “Server HD”
    6/14/12 8:33:03.575 PM Installer Free space on “Server HD”: 237.25 GB (237252562944 bytes).
    6/14/12 8:33:03.575 PM Installer Create temporary directory “/var/folders/lz/jbps0d1d4kz2j79hrmpnfrsr0000gn/T//Install.3110ZG8qsj”
    6/14/12 8:33:03.582 PM Installer IFPKInstallElement (1 packages)
    6/14/12 8:33:03.626 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.apple-software
    6/14/12 8:33:03.651 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.app-store-software
    6/14/12 8:33:03.676 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.app-store-software
    6/14/12 8:33:03.677 PM com.apple.SecurityServer Failed to authorize right ‘system.install.app-store-software’ by client ‘/System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd’ [3128] for authorization created by ‘/System/Library/CoreServices/Installer.app’ [3110]
    6/14/12 8:33:03.679 PM installd PackageKit: —– Begin install —–
    6/14/12 8:33:04.043 PM installd Installed “Calibrated{Q} MXF Import” ()
    6/14/12 8:33:04.046 PM installd PackageKit: —– End install —–
    6/14/12 8:33:04.683 PM Installer Running install actions
    6/14/12 8:33:04.684 PM Installer Removing temporary directory “/var/folders/lz/jbps0d1d4kz2j79hrmpnfrsr0000gn/T//Install.3110ZG8qsj”
    6/14/12 8:33:04.687 PM Installer Finalize disk “Server HD”
    6/14/12 8:33:04.688 PM Installer Notifying system of updated components
    6/14/12 8:33:04.688 PM Installer **** Summary Information ****
    6/14/12 8:33:04.688 PM Installer Operation Elapsed time
    6/14/12 8:33:04.688 PM Installer —————————–
    6/14/12 8:33:04.688 PM Installer disk 0.01 seconds
    6/14/12 8:33:04.688 PM Installer script 0.00 seconds
    6/14/12 8:33:04.688 PM Installer zero 0.01 seconds
    6/14/12 8:33:04.688 PM Installer install 1.10 seconds
    6/14/12 8:33:04.688 PM Installer -total- 1.12 seconds
    6/14/12 8:33:04.850 PM Installer IFDInstallController FBE32D90 state = 5
    6/14/12 8:33:04.850 PM Installer Displaying ‘Install Succeeded’ UI.
    6/14/12 8:34:14.786 PM com.logmein.logmeinguiagent 2012-06-14 20:34:14.785 – Debug – LMIGUIAgent – Graphics – Clipboard has been changed
    6/14/12 8:34:19.745 PM CalibratedQMXFOptions kCGErrorInvalidConnection: CGSGetWindowTags: Invalid connection
    6/14/12 8:34:19.745 PM CalibratedQMXFOptions kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
    6/14/12 8:35:26.019 PM CalibratedQMXFOptions kCGErrorInvalidConnection: CGSGetWindowTags: Invalid connection
    6/14/12 8:35:40.333 PM Finder SharePointBrowser::handleOpenCallBack returned -5996
    6/14/12 8:35:41.000 PM kernel smb_smb_negotiate: Support for the server HD-HTGLA3D has been deprecated (PreXP), disconnecting
    6/14/12 8:35:43.000 PM kernel smb_smb_negotiate: Support for the server HD-HTGLA3D has been deprecated (PreXP), disconnecting
    6/14/12 8:35:44.053 PM Finder SharePointBrowser::handleOpenCallBack returned -5996
    6/14/12 8:35:44.000 PM kernel smb_smb_negotiate: Support for the server HD-HTGLA3D has been deprecated (PreXP), disconnecting
    6/14/12 8:42:27.006 PM com.logmein.logmeinguiagent 2012-06-14 20:42:27.005 – Debug – LMIGUIAgent – Timer – Stopping timer
    6/14/12 8:42:27.316 PM com.logmein.logmeinguiagent 2012-06-14 20:42:27.316 – Debug – LMIGUIAgent – SessionManager – Got HideDialog 0
    6/14/12 8:42:27.348 PM LogMeInGUI String:RC:INACTIVE
    6/14/12 8:42:27.349 PM LogMeInGUI remoteControl:INACTIVE
    6/14/12 8:42:28.563 PM LogMeInGUI String:GUIMSG:USERLOGOFF
    6/14/12 8:44:20.848 PM LogMeInGUI String:GUIMSG:USERLOGON
    6/14/12 8:44:27.751 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.751 – Debug – LMIGUIAgent – SessionManager – Got DisplayDialog 0
    6/14/12 8:44:27.751 PM LogMeInGUI String:RC:ACTIVE
    6/14/12 8:44:27.752 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.751 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification LogMeIn – Remote Session
    6/14/12 8:44:27.752 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.752 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification – height 65 textSize: 266 35 text: This computer is being remote controlled by cjohnson from mail.bbwcg.com.
    6/14/12 8:44:27.753 PM LogMeInGUI remoteControl:ACTIVE
    6/14/12 8:44:27.755 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.754 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 8:44:27.757 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.757 – Debug – LMIGUIAgent – Timer – Stopping timer
    6/14/12 8:44:27.758 PM com.logmein.logmeinguiagent 2012-06-14 20:44:27.757 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 8:45:43.029 PM CalibratedQMXFOptions kCGErrorInvalidConnection: CGSGetWindowTags: Invalid connection
    6/14/12 8:49:52.317 PM DiskImages UI Agent *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
    6/14/12 8:49:52.317 PM [0x0-0x59059].com.apple.DiskImageMounter 2012-06-14 20:49:52.315 DiskImages UI Agent[3414:707] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
    6/14/12 8:49:54.226 PM Installer @(#)PROGRAM:Install PROJECT:Install-690
    6/14/12 8:49:54.226 PM Installer @(#)PROGRAM:Installer PROJECT:Installer-537
    6/14/12 8:49:54.226 PM Installer Hardware: Macmini5,3 @ 2.00 GHz (x 8), 8192 MB RAM
    6/14/12 8:49:54.227 PM Installer Running OS Build: Mac OS X 10.7.4 (11E53)
    6/14/12 8:49:54.284 PM Installer P2Store Driver Installation Log
    6/14/12 8:49:54.284 PM Installer Opened from: /Volumes/P2StoreDriver_v1_10/P2StoreDriver.pkg
    6/14/12 8:49:56.474 PM Installer InstallerStatusNotifications plugin loaded
    6/14/12 8:50:12.812 PM Installer ================================================================================
    6/14/12 8:50:12.812 PM Installer User picked Standard Install
    6/14/12 8:50:12.813 PM Installer Choices selected for installation:
    6/14/12 8:50:12.813 PM Installer Install: “P2Store Driver”
    6/14/12 8:50:12.813 PM Installer ================================================================================
    6/14/12 8:50:12.839 PM Installer Configuring volume “Server HD”
    6/14/12 8:50:12.853 PM Installer Free space on “Server HD”: 237.23 GB (237231341568 bytes).
    6/14/12 8:50:12.853 PM Installer Create temporary directory “/var/folders/lz/jbps0d1d4kz2j79hrmpnfrsr0000gn/T//Install.3427CyoSD8”
    6/14/12 8:50:12.858 PM Installer IFPKInstallElement (1 packages)
    6/14/12 8:50:12.896 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.apple-software
    6/14/12 8:50:12.919 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.app-store-software
    6/14/12 8:50:12.942 PM authorizationhost SFBuiltinEntitled: Installer.app is not entitled for system.install.app-store-software
    6/14/12 8:50:12.943 PM com.apple.SecurityServer Failed to authorize right ‘system.install.app-store-software’ by client ‘/System/Library/PrivateFrameworks/PackageKit.framework/Versions/A/Resources/installd’ [3467] for authorization created by ‘/System/Library/CoreServices/Installer.app’ [3427]
    6/14/12 8:50:12.945 PM installd PackageKit: —– Begin install —–
    6/14/12 8:50:16.630 PM xpchelper could not open dyld map file: (null)
    6/14/12 8:50:23.970 PM com.apple.kextcache / locked; waiting for lock.
    6/14/12 8:50:32.125 PM com.apple.kextcache / locked; waiting for lock.
    6/14/12 8:50:41.549 PM com.apple.efilogin-helper ImageIO: CGImageDestinationAddImage image parameter is nil
    6/14/12 8:50:41.549 PM com.apple.efilogin-helper ImageIO: CGImageDestinationFinalize image destination does not have enough images
    6/14/12 8:50:43.881 PM com.apple.kextcache Lock acquired; proceeding.
    6/14/12 8:50:43.887 PM com.apple.kextcache /: no supported helper partitions to update.
    6/14/12 8:50:43.887 PM com.apple.kextcache Lock acquired; proceeding.
    6/14/12 8:50:43.893 PM com.apple.kextcache /: no supported helper partitions to update.
    6/14/12 8:50:43.980 PM installd Installed “P2Store Driver” ()
    6/14/12 8:50:43.984 PM installd PackageKit: —– End install —–
    6/14/12 8:50:44.966 PM Installer Removing temporary directory “/var/folders/lz/jbps0d1d4kz2j79hrmpnfrsr0000gn/T//Install.3427CyoSD8”
    6/14/12 8:50:44.969 PM Installer Finalize disk “Server HD”
    6/14/12 8:50:44.969 PM Installer Notifying system of updated components
    6/14/12 8:50:44.970 PM Installer **** Summary Information ****
    6/14/12 8:50:44.970 PM Installer Operation Elapsed time
    6/14/12 8:50:44.970 PM Installer —————————–
    6/14/12 8:50:44.970 PM Installer zero 0.01 seconds
    6/14/12 8:50:44.970 PM Installer disk 0.01 seconds
    6/14/12 8:50:44.970 PM Installer install 32.11 seconds
    6/14/12 8:50:44.970 PM Installer -total- 32.13 seconds
    6/14/12 8:50:45.130 PM Installer IFDInstallController A3308720 state = 5
    6/14/12 8:50:45.130 PM Installer Displaying ‘Install Succeeded’ UI.
    6/14/12 8:51:05.780 PM servermgrd servermgr_filebrowser:Error:servermgr_filebrowser: Error getting quotas for volume /Volumes/share of type smbfs
    6/14/12 8:51:22.246 PM UserEventAgent WebUserEventAgent: record add/delete
    6/14/12 8:51:22.253 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.256 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.259 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.262 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.265 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.269 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.272 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.275 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.279 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.282 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.329 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.377 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.419 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.458 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.499 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.541 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.582 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.630 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.672 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.748 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.753 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.795 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.837 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.878 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.918 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:22.961 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.005 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.046 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.087 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.090 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.094 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.097 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.100 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 8:51:23.294 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 8:51:23.334 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 8:51:23.788 PM servermgrd servermgr_smb: -[SCSMBConfigurationParser writeFile] kSMBPreferencesSyncTool
    6/14/12 8:51:24.019 PM rpcsvchost sandbox_init: com.apple.msrpc.netlogon.sb succeeded
    6/14/12 8:51:24.296 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root
    6/14/12 8:51:24.297 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root
    6/14/12 8:51:24.299 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root
    6/14/12 8:51:24.300 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 8:51:24.302 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-data /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 8:51:24.303 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root
    6/14/12 8:51:24.304 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 8:51:24.305 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-data /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 8:51:24.307 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 8:51:24.308 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-data /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 8:51:24.309 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-metadata /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 8:51:24.311 PM sandboxd ([3535]) rpcsvchost(3535) deny file-read-data /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 8:51:29.662 PM servermgrd servermgr_filebrowser:Error:servermgr_filebrowser: Error getting quotas for volume /Volumes/share of type smbfs
    6/14/12 8:51:34.464 PM UserEventAgent WebUserEventAgent: record add/delete
    6/14/12 8:52:13.082 PM servermgrd servermgr_smb: -[SCSMBConfigurationParser writeFile] kSMBPreferencesSyncTool
    6/14/12 8:52:17.379 PM CalibratedQMXFOptions kCGErrorInvalidConnection: CGSGetWindowTags: Invalid connection
    6/14/12 8:55:02.559 PM sandboxd ([3615]) smbd(3615) deny job-creation
    6/14/12 8:57:35.750 PM com.logmein.logmeinguiagent 2012-06-14 20:57:35.750 – Debug – LMIGUIAgent – Timer – Stopping timer
    6/14/12 8:57:35.874 PM com.logmein.logmeinguiagent 2012-06-14 20:57:35.874 – Debug – LMIGUIAgent – SessionManager – Got HideDialog 0
    6/14/12 8:57:35.906 PM LogMeInGUI String:RC:INACTIVE
    6/14/12 8:57:35.907 PM LogMeInGUI remoteControl:INACTIVE
    6/14/12 9:00:26.600 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 9:00:26.639 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 9:16:23.837 PM LogMeInGUI String:RC:ACTIVE
    6/14/12 9:16:23.837 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.837 – Debug – LMIGUIAgent – SessionManager – Got DisplayDialog 0
    6/14/12 9:16:23.838 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.837 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification LogMeIn – Remote Session
    6/14/12 9:16:23.838 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.837 – Debug – LMIGUIAgent – ToolbarNotificationWindowController – setRCNotification – height 65 textSize: 266 35 text: This computer is being remote controlled by cjohnson from mail.bbwcg.com.
    6/14/12 9:16:23.839 PM LogMeInGUI remoteControl:ACTIVE
    6/14/12 9:16:23.840 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.839 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 9:16:23.842 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.842 – Debug – LMIGUIAgent – Timer – Stopping timer
    6/14/12 9:16:23.843 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.842 – Debug – LMIGUIAgent – Timer – Starting timer
    6/14/12 9:16:23.850 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.849 – Debug – LMIGUIAgent – Graphics – Display is asleep in copyToBitmapUsingQuartz.
    6/14/12 9:16:23.850 PM com.logmein.logmeinguiagent 2012-06-14 21:16:23.849 – Debug – LMIGUIAgent – Display – Waking up the display.
    6/14/12 9:16:24.046 PM LogMeInGUI RegistryAccess.loadFromFile stringWithContentsOfFile Error: Error Domain=NSCocoaErrorDomain Code=260 “The file “config.xml” couldn’t be opened because there is no such file.” UserInfo=0x54e260 {NSFilePath=/Library/Application Support/LogMeIn/config.xml, NSUnderlyingError=0x548690 “The operation couldn’t be completed. No such file or directory”} ‘/Library/Application Support/LogMeIn/config.xml’
    6/14/12 9:20:49.956 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 9:20:49.958 PM servermgrd servermgr_smb: -[SCSMBConfigurationParser writeFile] kSMBPreferencesSyncTool
    6/14/12 9:20:49.970 PM rpcsvchost sandbox_init: com.apple.msrpc.netlogon.sb succeeded
    6/14/12 9:20:50.033 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv4 rules
    6/14/12 9:20:50.155 PM servermgrd servermgr_ipfilter:ipfw config:Notice:Flushed IPv6 rules
    6/14/12 9:20:50.272 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root
    6/14/12 9:20:50.274 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root
    6/14/12 9:20:50.275 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root
    6/14/12 9:20:50.277 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 9:20:50.278 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-data /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 9:20:50.279 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root
    6/14/12 9:20:50.280 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 9:20:50.282 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-data /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 9:20:50.283 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 9:20:50.285 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-data /private/var/root/Library/Preferences/ByHost/.GlobalPreferences.883076F2-987B-531C-B635-7B95C466E4D7.plist
    6/14/12 9:20:50.286 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-metadata /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 9:20:50.287 PM sandboxd ([3808]) rpcsvchost(3808) deny file-read-data /private/var/root/Library/Preferences/.GlobalPreferences.plist
    6/14/12 9:20:57.879 PM UserEventAgent get_backup_share_points no AFP
    6/14/12 9:20:57.879 PM UserEventAgent WebUserEventAgent: record add/delete
    6/14/12 9:20:58.537 PM com.apple.launchd (com.apple.smb.preferences) Throttling respawn: Will start in 2 seconds
    6/14/12 9:20:58.550 PM servermgrd servermgr_smb: -[SCSMBConfigurationParser writeFile] kSMBPreferencesSyncTool
    6/14/12 9:21:02.906 PM UserEventAgent WebUserEventAgent: record add/delete
    6/14/12 9:21:03.474 PM com.apple.launchd (com.apple.smb.preferences) Throttling respawn: Will start in 8 seconds
    6/14/12 9:21:03.486 PM servermgrd servermgr_smb: -[SCSMBConfigurationParser writeFile] kSMBPreferencesSyncTool
    6/14/12 9:24:21.485 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:24:21.485 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:24:56.247 PM com.logmein.logmeinguiagent 2012-06-14 21:24:56.246 – Debug – LMIGUIAgent – Graphics – Clipboard has been changed
    6/14/12 9:25:25.288 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:25:25.288 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:25:32.983 PM sandboxd ([3217]) TextEdit(3217) deny file-write-data /
    6/14/12 9:25:35.260 PM com.logmein.logmeinguiagent 2012-06-14 21:25:35.259 – Debug – LMIGUIAgent – Graphics – Clipboard has been changed
    6/14/12 9:25:36.877 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:25:36.877 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:25:36.898 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:25:36.898 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:26:06.479 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:26:06.480 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:26:06.496 PM sandboxd ([3217]) TextEdit(3217) deny system-fsctl
    6/14/12 9:26:06.496 PM TextEdit Failed to get user access for mount /Volumes/share
    6/14/12 9:26:16.582 PM [0x0-0x19019].uk.co.squarebox.ControlPanel auth[0]: /usr/local/mysql/support-files/mysql.server
    6/14/12 9:26:16.582 PM [0x0-0x19019].uk.co.squarebox.ControlPanel auth[1]: stop
    6/14/12 9:26:16.583 PM com.apple.SecurityServer Failed to authorize right ” by client ‘/Applications/CatDV Control Panel.app’ [602] for authorization created by ‘/Applications/CatDV Control Panel.app’ [602]
    6/14/12 9:26:26.795 PM authexec executing /usr/local/mysql/support-files/mysql.server
    6/14/12 9:26:29.799 PM [0x0-0x19019].uk.co.squarebox.ControlPanel auth ok
    6/14/12 9:26:34.874 PM [0x0-0x19019].uk.co.squarebox.ControlPanel exec[0]: /Library/Tomcat/bin/shutdown.sh
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel com.mysql.jdbc.CommunicationsException: Communications link failure due to underlying exception:
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel ** BEGIN NESTED EXCEPTION **
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel java.net.SocketException
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel MESSAGE: java.net.ConnectException: Connection refused
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel STACKTRACE:
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel java.net.SocketException: java.net.ConnectException: Connection refused
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:156)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.MysqlIO.(MysqlIO.java:284)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.Connection.createNewIO(Connection.java:2555)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.Connection.(Connection.java:1485)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:266)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.sql.DriverManager.getConnection(DriverManager.java:582)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.sql.DriverManager.getConnection(DriverManager.java:207)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8.$1(Unknown Source)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8.$0(Unknown Source)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8$3.run(Unknown Source)
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel ** END NESTED EXCEPTION **
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Last packet sent to the server was 3 ms ago.
    6/14/12 9:26:34.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at com.mysql.jdbc.Connection.createNewIO(Connection.java:2621)
    6/14/12 9:26:44.892 PM [0x0-0x19019].uk.co.squarebox.ControlPanel java.rmi.ConnectException: Connection refused to host: 10.0.1.22; nested exception is:
    6/14/12 9:26:44.892 PM [0x0-0x19019].uk.co.squarebox.ControlPanel java.net.ConnectException: Connection refused
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:601)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.tcp.TCPChannel.createConnection(TCPChannel.java:198)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.tcp.TCPChannel.newConnection(TCPChannel.java:184)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.server.UnicastRef.newCall(UnicastRef.java:322)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.registry.RegistryImpl_Stub.lookup(Unknown Source)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.rmi.Naming.lookup(Naming.java:84)
    6/14/12 9:26:44.894 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8.$23(Unknown Source)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8.$1(Unknown Source)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at squarebox.catdv.server.control.$8$4.run(Unknown Source)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel Caused by: java.net.ConnectException: Connection refused
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.PlainSocketImpl.socketConnect(Native Method)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:432)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.Socket.connect(Socket.java:529)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.Socket.connect(Socket.java:478)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.Socket.(Socket.java:375)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at java.net.Socket.(Socket.java:189)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.proxy.RMIDirectSocketFactory.createSocket(RMIDirectSocketFactory.java:22)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.proxy.RMIMasterSocketFactory.createSocket(RMIMasterSocketFactory.java:128)
    6/14/12 9:26:44.895 PM [0x0-0x19019].uk.co.squarebox.ControlPanel at sun.rmi.transport.tcp.TCPEndpoint.newSocket(TCPEndpoint.java:595)
    6/14/12 9:26:44.896 PM [0x0-0x19019].uk.co.squarebox.ControlPanel … 8 more
    6/14/12 9:26:57.549 PM com.apple.launchd.peruser.501 ([0x0-0x35035].com.apple.Console[2164]) Exited: Killed: 9
    6/14/12 9:26:57.595 PM com.logmein.logmeinguiagent 2012-06-14 21:26:57.594 – Debug – LMIGUIAgent – SessionManager – Application exiting
    6/14/12 9:26:57.597 PM mds (Error) Server: ==== XPC handleXPCMessage XPC_ERROR_CONNECTION_INVALID
    6/14/12 9:26:57.598 PM com.apple.launchd.peruser.501 (com.apple.talagent[284]) Exited: Killed: 9
    6/14/12 9:26:57.604 PM com.apple.launchd.peruser.501 ([0x0-0x17017].com.apple.AppleSpell[489]) Exited: Killed: 9
    6/14/12 9:26:57.605 PM com.apple.launchd.peruser.501 (com.apple.mdworker.pool.1[3868]) Exited: Terminated: 15
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent Session – Error occured:read errno: (9) Bad file descriptor
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent 2012-06-14 21:26:57.605 – Debug – LMIGUIAgent – SessionManager – Connection closed
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent 2012-06-14 21:26:57.605 – Debug – LMIGUIAgent – SessionManager – Closing DisplayServer
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent 2012-06-14 21:26:57.605 – Debug – LMIGUIAgent – SessionManager – DisplayServer close
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent 2012-06-14 21:26:57.605 – Debug – LMIGUIAgent – Graphics – Stopping Display server
    6/14/12 9:26:57.606 PM com.logmein.logmeinguiagent pure virtual method called
    6/14/12 9:26:57.634 PM loginwindow DEAD_PROCESS: 91 console
    6/14/12 9:26:57.661 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.661 PM com.apple.dock.extra 2012-06-14 21:26:57.660 com.apple.dock.extra[4020:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.662 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.662 PM com.apple.dock.extra 2012-06-14 21:26:57.661 com.apple.dock.extra[4020:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.663 PM com.apple.dock.extra 2012-06-14 21:26:57.661 com.apple.dock.extra[4020:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.663 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:57.663 PM com.apple.dock.extra 2012-06-14 21:26:57.662 com.apple.dock.extra[4020:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:26:58.015 PM shutdown reboot by cjohnson:
    6/14/12 9:26:58.016 PM shutdown SHUTDOWN_TIME: 1339727218 15426
    6/14/12 9:27:28.000 PM bootlog BOOT_TIME 1339727248 0
    6/14/12 9:27:29.000 PM kernel PMAP: PCID enabled
    6/14/12 9:27:29.000 PM kernel Darwin Kernel Version 11.4.0: Mon Apr 9 19:32:15 PDT 2012; root:xnu-1699.26.8~1/RELEASE_X86_64
    6/14/12 9:27:29.000 PM kernel vm_page_bootstrap: 2009959 free pages and 70809 wired pages
    6/14/12 9:27:29.000 PM kernel kext submap [0xffffff7f80732000 – 0xffffff8000000000], kernel text [0xffffff8000200000 – 0xffffff8000732000]
    6/14/12 9:27:29.000 PM kernel zone leak detection enabled
    6/14/12 9:27:29.000 PM kernel standard timeslicing quantum is 10000 us
    6/14/12 9:27:29.000 PM kernel mig_table_max_displ = 73
    6/14/12 9:27:29.000 PM kernel TSC Deadline Timer supported and enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=4 LocalApicId=6 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=5 LocalApicId=1 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=6 LocalApicId=3 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=7 LocalApicId=5 Enabled
    6/14/12 9:27:29.000 PM kernel AppleACPICPU: ProcessorId=8 LocalApicId=7 Enabled
    6/14/12 9:27:29.000 PM kernel calling mpo_policy_init for TMSafetyNet
    6/14/12 9:27:29.000 PM kernel Security policy loaded: Safety net for Time Machine (TMSafetyNet)
    6/14/12 9:27:29.000 PM kernel calling mpo_policy_init for Sandbox
    6/14/12 9:27:29.000 PM kernel Security policy loaded: Seatbelt sandbox policy (Sandbox)
    6/14/12 9:27:29.000 PM kernel calling mpo_policy_init for Quarantine
    6/14/12 9:27:29.000 PM kernel Security policy loaded: Quarantine policy (Quarantine)
    6/14/12 9:27:29.000 PM kernel Copyright (c) 1982, 1986, 1989, 1991, 1993
    6/14/12 9:27:29.000 PM kernel The Regents of the University of California. All rights reserved.
    6/14/12 9:27:29.000 PM kernel MAC Framework successfully initialized
    6/14/12 9:27:29.000 PM kernel using 16384 buffer headers and 10240 cluster IO buffer headers
    6/14/12 9:27:29.000 PM kernel IOAPIC: Version 0x20 Vectors 64:87
    6/14/12 9:27:29.000 PM kernel ACPI: System State [S0 S3 S4 S5]
    6/14/12 9:27:29.000 PM kernel PFM64 (36 cpu) 0xf10000000, 0xf0000000
    6/14/12 9:27:29.000 PM kernel [ PCI configuration begin ]
    6/14/12 9:27:29.000 PM kernel AppleIntelCPUPowerManagement: Turbo Ratios 6689
    6/14/12 9:27:29.000 PM kernel AppleIntelCPUPowerManagement: (built 19:39:51 Apr 9 2012) initialization complete
    6/14/12 9:27:29.000 PM kernel console relocated to 0xf11000000
    6/14/12 9:27:29.000 PM kernel PCI configuration changed (bridge=37 device=5 cardbus=0)
    6/14/12 9:27:29.000 PM kernel [ PCI configuration end, bridges 17 devices 17 ]
    6/14/12 9:27:29.000 PM kernel mbinit: done [96 MB total pool size, (64/32) split]
    6/14/12 9:27:29.000 PM kernel Pthread support ABORTS when sync kernel primitives misused
    6/14/12 9:27:29.000 PM kernel com.apple.AppleFSCompressionTypeZlib kmod start
    6/14/12 9:27:29.000 PM kernel com.apple.AppleFSCompressionTypeDataless kmod start
    6/14/12 9:27:29.000 PM kernel com.apple.AppleFSCompressionTypeZlib load succeeded
    6/14/12 9:27:29.000 PM kernel com.apple.AppleFSCompressionTypeDataless load succeeded
    6/14/12 9:27:29.000 PM kernel AppleIntelCPUPowerManagementClient: ready
    6/14/12 9:27:29.000 PM kernel BTCOEXIST off
    6/14/12 9:27:29.000 PM kernel wl0: Broadcom BCM4331 802.11 Wireless Controller
    6/14/12 9:27:29.000 PM kernel 5.106.198.4
    6/14/12 9:27:29.000 PM kernel FireWire (OHCI) TI ID 823f built-in now active, GUID 406c8ffffeb4d61a; max speed s800.
    6/14/12 9:27:29.000 PM kernel rooting via boot-uuid from /chosen: CE0941FB-1C51-35EF-A45D-E27531271D4B
    6/14/12 9:27:29.000 PM kernel Waiting on IOProviderClassIOResourcesIOResourceMatchboot-uuid-media
    6/14/12 9:27:29.000 PM kernel Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/APPLE SSD TS256C Media/IOGUIDPartitionScheme/Customer@2
    6/14/12 9:27:29.000 PM kernel BSD root: disk0s2, major 14, minor 2
    6/14/12 9:27:29.000 PM kernel Kernel is LP64
    6/14/12 9:27:29.000 PM kernel [IOBluetoothHCIController::setConfigState] calling registerService
    6/14/12 9:27:29.000 PM kernel IPv6 packet filtering initialized, default to accept, logging disabled
    6/14/12 9:27:29.122 PM com.apple.launchd *** launchd[1] has started up. ***
    6/14/12 9:27:29.686 PM com.apple.launchd (com.promise.httpd) Unknown key for boolean: OnLoad
    6/14/12 9:27:29.689 PM com.apple.launchd (com.apple.powerd) Unknown value for key POSIXSpawnType: Interactive
    6/14/12 9:27:29.690 PM com.apple.launchd (com.apple.sandboxd) Unknown value for key POSIXSpawnType: Interactive
    6/14/12 9:27:29.694 PM com.apple.launchd (com.apple.xgridd.pcastserver) Bug: launchd_core_logic.c:5193 (25693):2
    6/14/12 9:27:29.694 PM com.apple.launchd (com.apple.xgridd.pcastserver) Path monitoring failed on “/var/pcast/server/xgridd/keepalive”: No such file or directory
    6/14/12 9:27:30.000 PM kernel AirPort_Brcm4331: Ethernet address 80:49:71:14:6c:83
    6/14/12 9:27:30.000 PM kernel IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
    6/14/12 9:27:30.000 PM kernel IO80211Interface::efiNVRAMPublished():
    6/14/12 9:27:30.266 PM UserEventAgent starting CaptiveNetworkSupport as SystemEventAgent built May 25 2011 12:27:35
    6/14/12 9:27:30.270 PM UserEventAgent CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found. 🙂
    6/14/12 9:27:30.270 PM UserEventAgent CaptiveNetworkSupport:CaptivePublishState:1211 en1 – PreProbe
    6/14/12 9:27:30.271 PM UserEventAgent CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
    6/14/12 9:27:30.271 PM UserEventAgent CaptiveNetworkSupport:CaptivePublishState:1211 en1 – PreProbe
    6/14/12 9:27:30.327 PM UserEventAgent CertsKeychainMonitor: configuring
    6/14/12 9:27:31.178 PM com.apple.SecurityServer Session 100000 created
    6/14/12 9:27:31.304 PM com.apple.SecurityServer Entering service
    6/14/12 9:27:31.544 PM mDNSResponder mDNSResponder mDNSResponder-320.16 (Mar 17 2012 21:31:16) starting OSXVers 11
    6/14/12 9:27:31.546 PM airportd _processDLILEvent: en1 attached (down)
    6/14/12 9:27:31.000 PM kernel IOSCSITargetDevice::RetrieveINQUIRYDataPage: Inquiry Failed for page 0
    6/14/12 9:27:31.000 PM kernel in func createVirtualInterface ifRole = 1
    6/14/12 9:27:31.000 PM kernel Created virtif 0xffffff80129dba00 p2p0
    6/14/12 9:27:31.000 PM kernel AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
    6/14/12 9:27:31.580 PM UserEventAgent CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
    6/14/12 9:27:31.581 PM UserEventAgent CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
    6/14/12 9:27:31.597 PM UserEventAgent CaptiveNetworkSupport:CaptivePublishState:1211 en1 – PreProbe
    6/14/12 9:27:31.599 PM configd bootp_session_transmit: bpf_write(en1) failed: Network is down (50)
    6/14/12 9:27:31.599 PM configd DHCP en1: INIT transmit failed
    6/14/12 9:27:31.630 PM configd setting hostname to “catdv.bbwcg.local”
    6/14/12 9:27:31.634 PM configd network configuration changed.
    6/14/12 9:27:31.672 PM systemkeychain done file: /var/run/systemkeychaincheck.done
    6/14/12 9:27:31.683 PM configd network configuration changed.
    6/14/12 9:27:31.000 PM kernel BCM5701Enet: Ethernet address 40:6c:8f:39:fb:d3
    6/14/12 9:27:31.685 PM configd network configuration changed.
    6/14/12 9:27:31.692 PM mDNSResponder D2D_IPC: Loaded
    6/14/12 9:27:31.692 PM mDNSResponder D2DInitialize succeeded
    6/14/12 9:27:32.000 PM kernel Previous Shutdown Cause: 0
    6/14/12 9:27:32.000 PM kernel SMC::smcInitHelper ERROR: MMIO regMap == NULL – fall back to old SMC mode
    6/14/12 9:27:32.328 PM UserEventAgent WebUserEventAgent: installed
    6/14/12 9:27:33.000 PM kernel ioqueue_depth = 1023, ioscale = 32
    6/14/12 9:27:33.000 PM kernel DSMOS has arrived
    6/14/12 9:27:33.742 PM UserEventAgent Registered Workstation service – catdv [40:6c:8f:39:fb:d3]._workstation._tcp.
    6/14/12 9:27:35.000 PM kernel Ethernet [AppleBCM5701Ethernet]: Link up on en0, 1-Gigabit, Full-duplex, No flow-control, Debug [796d,2301,0de1,0300,c1e1,3800]
    6/14/12 9:27:36.478 PM com.apple.pfctl No ALTQ support in kernel
    6/14/12 9:27:36.478 PM com.apple.pfctl ALTQ related functions disabled
    6/14/12 9:27:36.514 PM com.apple.ucupdate.plist ucupdate: Checked 1 update, no match found.
    6/14/12 9:27:36.552 PM named starting BIND 9.7.3-P3 -f
    6/14/12 9:27:36.552 PM named built with ‘–mandir=/usr/share/man’ ‘–infodir=/usr/share/info’ ‘–disable-dependency-tracking’ ‘–prefix=/usr’ ‘–sysconfdir=/private/etc’ ‘–localstatedir=/private/var’ ‘–enable-atomic=no’ ‘–with-openssl=yes’ ‘–with-gssapi=yes’ ‘–enable-symtable=none’ ‘CFLAGS=-arch x86_64 -arch i386 -g -Os -pipe -gdwarf-2 -D__APPLE_USE_RFC_2292’ ‘LDFLAGS=-arch x86_64 -arch i386 ‘ ‘CXXFLAGS=-arch x86_64 -arch i386 -g -Os -pipe ‘
    6/14/12 9:27:36.557 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:36.564 PM com.apple.SystemStarter Starting MySQL database server
    6/14/12 9:27:36.678 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:36.812 PM named command channel listening on 127.0.0.1#54
    6/14/12 9:27:36.845 PM com.apple.usbmuxd usbmuxd-268.5 on Apr 5 2012 at 15:33:48, running 64 bit
    6/14/12 9:27:36.000 PM kernel macx_swapon SUCCESS
    6/14/12 9:27:36.923 PM com.apple.launchd (0x103905310.anonymous.nohup[199]) Bug: launchd_core_logic.c:9394 (25693):0
    6/14/12 9:27:36.923 PM com.apple.launchd (0x103905310.anonymous.nohup[199]) Switching sessions is not allowed in the system Mach bootstrap.
    6/14/12 9:27:36.923 PM com.apple.launchd (0x103905310.anonymous.nohup[199]) _vprocmgr_switch_to_session(): kr = 0x44c
    6/14/12 9:27:36.925 PM com.apple.launchd (0x7fb2b8501820.anonymous.nohup[200]) Bug: launchd_core_logic.c:9394 (25693):0
    6/14/12 9:27:36.925 PM com.apple.launchd (0x7fb2b8501820.anonymous.nohup[200]) Switching sessions is not allowed in the system Mach bootstrap.
    6/14/12 9:27:36.925 PM com.apple.launchd (0x7fb2b8501820.anonymous.nohup[200]) _vprocmgr_switch_to_session(): kr = 0x44c
    6/14/12 9:27:36.989 PM loginwindow Login Window Application Started
    6/14/12 9:27:37.056 PM mds (Normal) FMW: FMW 0 0
    6/14/12 9:27:37.396 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:37.604 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:40.000 PM kernel EDID CEA Extensions not valid for audio [no extended EDID]
    6/14/12 9:27:41.080 PM WindowServer (ipc/send) invalid destination port: IOServiceWaitQuiet for CGXMappedDisplayStart
    6/14/12 9:27:41.080 PM WindowServer kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
    6/14/12 9:27:41.216 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:41.219 PM mDNSResponder queryrecord_result_callback: ERROR!! answering multicast question with unicast cache record
    6/14/12 9:27:41.258 PM loginwindow **DMPROXY** Found `/System/Library/CoreServices/DMProxy’.
    6/14/12 9:27:41.410 PM com.apple.launchd (com.logmein.logmeinguiagentatlogin) Unknown key for boolean: UseLMILaunchAgentFixer
    6/14/12 9:27:41.413 PM com.apple.launchctl.LoginWindow com.apple.findmymacmessenger: Already loaded
    6/14/12 9:27:41.492 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.491 – Info – LMIGUIAgent – Main – starting…
    6/14/12 9:27:41.506 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.505 – Debug – LMIGUIAgent – GetCurrentSessionID() – Current SessionID is -1
    6/14/12 9:27:41.506 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.505 – Info – LMIGUIAgent – Main – started:252 uid:0, sessionid:-1 (parent:1 launchd)
    6/14/12 9:27:41.506 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.505 – Info – LMIGUIAgent – Main – checking window server connection
    6/14/12 9:27:41.507 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.506 – Info – LMIGUIAgent – Main – checking window server session
    6/14/12 9:27:41.507 PM com.logmein.logmeinguiagentatlogin 2012-06-14 21:27:41.507 – Info – LMIGUIAgent – Main – connecting to session manager
    6/14/12 9:27:41.546 PM com.apple.SecurityServer Session 100005 created
    6/14/12 9:27:41.548 PM loginwindow Login Window Started Security Agent
    6/14/12 9:27:41.631 PM SecurityAgent Echo enabled
    6/14/12 9:27:41.679 PM SecurityAgent User info context values set for cjohnson
    6/14/12 9:27:41.686 PM PasswordService -[PasswordServerPrefsObject getSearchBase]: Unable to locate search base: -1 Can’t contact LDAP server
    6/14/12 9:27:41.687 PM PasswordService -[PasswordServerPrefsObject loadXMLData]: Unable to locate passwordserver config record’s plist attribute: -1 Can’t contact LDAP server
    6/14/12 9:27:41.688 PM PasswordService -[PasswordServerPrefsObject getSearchBase]: Unable to locate search base: -1 Can’t contact LDAP server
    6/14/12 9:27:41.688 PM PasswordService -[PasswordServerPrefsObject saveXMLData]: ldap_modify_ext_s of the passwordserver config record’s plist attribute: -1 Can’t contact LDAP server
    6/14/12 9:27:42.009 PM loginwindow Login Window – Returned from Security Agent
    6/14/12 9:27:42.024 PM loginwindow USER_PROCESS: 92 console
    6/14/12 9:27:42.136 PM com.apple.launchd.peruser.501 (com.logmein.logmeingui) Unknown key for boolean: UseLMILaunchAgentFixer
    6/14/12 9:27:42.137 PM com.apple.launchd.peruser.501 (com.logmein.logmeinguiagent) Unknown key for boolean: UseLMILaunchAgentFixer
    6/14/12 9:27:42.138 PM com.apple.launchd.peruser.501 (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
    6/14/12 9:27:42.141 PM com.apple.launchctl.Aqua load: option requires an argument — D
    6/14/12 9:27:42.141 PM com.apple.launchctl.Aqua usage: launchctl load [-wF] [-D ] paths…
    6/14/12 9:27:42.301 PM UserEventAgent CaptiveNetworkSupport:CNSServerRegisterUserAgent:187 new user agent port: 8199
    6/14/12 9:27:42.334 PM com.apple.launchd.peruser.501 (com.apple.launchctl.Aqua[278]) Exited with code: 1
    6/14/12 9:27:42.397 PM org.apache.httpd httpd: apr_sockaddr_info_get() failed for catdv.bbwcg.local
    6/14/12 9:27:42.397 PM org.apache.httpd httpd: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1 for ServerName
    6/14/12 9:27:42.606 PM com.promise.httpd httpd: apr_sockaddr_info_get() failed for catdv.bbwcg.local
    6/14/12 9:27:42.606 PM com.promise.httpd httpd: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1 for ServerName
    6/14/12 9:27:42.899 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.899 – Info – LMIGUIAgent – Main – starting…
    6/14/12 9:27:42.904 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.903 – Debug – LMIGUIAgent – GetCurrentSessionID() – Current SessionID is 501
    6/14/12 9:27:42.904 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.903 – Info – LMIGUIAgent – Main – started:326 uid:501, sessionid:501 (parent:274 launchd)
    6/14/12 9:27:42.904 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.903 – Info – LMIGUIAgent – Main – checking window server connection
    6/14/12 9:27:42.904 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.903 – Info – LMIGUIAgent – Main – checking window server session
    6/14/12 9:27:42.904 PM com.logmein.logmeinguiagent 2012-06-14 21:27:42.904 – Info – LMIGUIAgent – Main – connecting to session manager
    6/14/12 9:27:42.945 PM LogMeInGUI LogMeIn GUI started
    6/14/12 9:27:43.211 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.211 PM com.apple.dock.extra 2012-06-14 21:27:43.209 com.apple.dock.extra[335:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.212 PM com.apple.dock.extra 2012-06-14 21:27:43.210 com.apple.dock.extra[335:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.212 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.212 PM com.apple.dock.extra 2012-06-14 21:27:43.211 com.apple.dock.extra[335:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.213 PM com.apple.dock.extra Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.213 PM com.apple.dock.extra 2012-06-14 21:27:43.212 com.apple.dock.extra[335:1707] Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.319 PM LogMeInGUI Config watcher thread started
    6/14/12 9:27:43.450 PM LMIGUIAgent Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.451 PM LMIGUIAgent Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.452 PM LMIGUIAgent Could not connect the action buttonPressed: to target of class NSApplication
    6/14/12 9:27:43.461 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.461 – Debug – LMIGUIAgent – SessionManager – SessionAgent Loaded
    6/14/12 9:27:43.462 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.461 – Debug – LMIGUIAgent – SessionManager – SessionAgent Starting
    6/14/12 9:27:43.462 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.461 – Debug – LMIGUIAgent – GetCurrentSessionID() – Current SessionID is 501
    6/14/12 9:27:43.464 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.464 – Debug – LMIGUIAgent – GetCurrentSessionID() – Current SessionID is 501
    6/14/12 9:27:43.464 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.464 – Debug – LMIGUIAgent – SessionManager – sessionStateChanged activated=1 sessionid=501 consoleuser=cjohnson IsAtActiveConsole=1 SessionIsLoggedIn=1 IsOnLoginScreen=0
    6/14/12 9:27:43.465 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.464 – Debug – LMIGUIAgent – GetCurrentSessionID() – Current SessionID is 501
    6/14/12 9:27:43.465 PM com.logmein.logmeinguiagent 2012-06-14 21:27:43.464 – Debug – LMIGUIAgent – SessionManager – SessionAgent Started
    6/14/12 9:27:43.606 PM LogMeInGUI remoteControl:INACTIVE
    6/14/12 9:27:43.606 PM LogMeInGUI String:RC:INACTIVE
    6/14/12 9:27:43.628 PM LogMeInGUI processLine:ACCESSMAS
  • Kevin Duggan
    June 18, 2012 at 7:34 am
    HI Chuck
    White screen in Qtime normally indicates no codec found for the movie… check to see you have them installed
    Kevin Duggan
    Kevin Duggan
    CatDV/MME
  • Chuck Johnson
    June 18, 2012 at 1:00 pm
    Hi Kevin,
    That’s exactly what it was – Greg with Calibrated came to the rescue and helped determine that was the issue.
    The strange thing was that I only had installed one of the codecs and everything was working fine. Once I updated to the latest server version, it stopped working and I got the white screens.
    Then, I updated the other two codecs and everything was fine. Greg said he was working on a chart of codecs/OS’s and other conditions that will show customers what codec is needed for specific workflows.
    Cheers!
    Chuck
