thumbnail refresh?
Posted by Ron Labbe on February 9, 2013 at 4:52 pmI’ve got a load of stills in the Media Bin. It takes a bit for all the thumbnails to load… if I scroll down, the thumbnails have to reload. If I scroll back up, they have to reload again. And again. How do I get the thumbnails to “stick”?? A cache problem? Thanks.
ron labbe
studio 3DRon Labbe replied 13 years, 7 months ago 2 Members · 6 Replies -
Larry Brewer
February 10, 2013 at 6:22 amRon
I’ve had the same problem from the get go with Vegas. I’ve asked about it on this forum, but never found a solution.
Ron Labbe
February 11, 2013 at 1:54 pmApparently the Sony forum is useless! Mine has now decided to go into “Not Responding” permanently mode after scrolling through a few “pages”. Argh.
ron labbe
studio 3D -
Larry Brewer
February 11, 2013 at 4:23 pmStrange you should mention that. I have been fighting the “not responding” for the last 24 hrs. When I commented on your post I hadn’t actually connected the thumbnail prob to Vegas locking up. The issue for me apparently was the upgrade I made last week to Vegas 12 Build 486. I have re-installed an earlier Vegas 12 Build 367, and the problem went away. ( the slow thumbnail creation and the re-building of thumbnails continues, but at least it doesn’t go into “not responding” and freeze up.)
Here’s the link to early Vegas versions and builds..
https://download.sonymediasoftware.com/current/
Ron Labbe
February 11, 2013 at 4:37 pmThanks… I’ll try the previous build as well. Suppose I have to uninstall first? Interestingly, I loaded (current) Sony Movie Studio to see how it behaved (trial version) and I get the exact same problems!
ron labbe
studio 3D -
Larry Brewer
February 12, 2013 at 7:32 amYes, you’ll have to uninstall the Version of Vegas 12 you have installed to go back to an earlier build. In this case, it’s well worth it.
Ron Labbe
February 12, 2013 at 3:30 pmYes, it’s still slow, must refresh continually (often takes several minutes), but at least it “recovers”. I see another thread popped up with the same problem! Only reason I use Sony is the incredible 3D support. Otherwise, ARGH!
ron labbe
studio 3D
