Activity Forums DaVinci Resolve Thumbnail Clips in Bins from range selection in out instead of first frame
  • Thumbnail Clips in Bins from range selection in out instead of first frame
    Posted by Mariano Puppo on February 28, 2018 at 5:35 pm
    Hi people,
    Sorry if this is a dumb question, but I can’t find a easy way to change all thumbnails of the clips inside a bin using the in selection instead of the footage first frame. For example I did a preselection I create a new bin, I drag all those cuts into the bin where some clips are from the same footage but different in-out moments of the video file but in the bin all thumbnails are the same for that footage it doesn’t respect the range selection. I can’t go manually scrubing each clip to just set a new thumbail I would like to know if there is an automatic way to switch all thumbnails of a bin into the first frame of the in-out selection instead of the first frame of the file.
    Mariano Puppo replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
