Activity › Forums › Adobe Encore DVD › THREE POSTS UN RESPONDED TOO??????
  • THREE POSTS UN RESPONDED TOO??????
    Posted by Joshua Weiss on September 17, 2005 at 5:11 pm
    First, for some reason, I run into this error poping up every time I try to burn a DVD from Encore. It always seems to be the animated buttons. The second the DVD begins to process the build, it pops up saying “Out of memory.” If I turn off the animated buttons, it works fine. I believe that I have enough memory. Any clue? This pops up on more than one system that I try to burn things on and it does it to more than one project of mine. This means that it is not easy to point it at the computer or the specific project.
    Second, I am having an issue where the audio stops playing during preview in Encore. This started happening when I started using subtitles. Any ideas?
    Third, I use a dual monitor setup. Every time I open the monitor in encore it sets the second monitor to the same thing only full screen. This covers up the rest of the desktop and I cannot get rid of it unless I close the monitor in Encore. HELP ME!
    If there is simply no fix for these problems, it would help to be told that.
    Josh
    Joshua Weiss replied 21 years ago 1 Member · 0 Replies
  • 0 Replies
