Activity Forums Adobe InDesign “threading text frames”
  • “threading text frames”
    Posted by The.true.ueli on July 21, 2006 at 12:24 pm
    hi everybody
    my girlfriend is currently doing her final diploma assessment and she’s got a problem i’m trying to help her with.
    how can i thread text frames without changing their outline nor moving the content of text frame B into text frame A?
    i’d be grateful for any sort of help.
    ps.: i’m currently using indesign cs
    Erica Gamet replied 20 years, 1 month ago 2 Members · 1 Reply
  • Erica Gamet
    July 21, 2006 at 11:04 pm
    If there is room in frame A, then text will flow backwards into that frame. If the text in A is at the end of a paragraph, you can choose to create a break in the text by hitting Enter (if you’re on a Mac…what is that on a PC? Not your regular Enter key, but the one that is on the 10-key?)…that will send the text to the next frame (if you have multiple columns, it will send it to the next column, so you may need to hit Enter again). Keep in mind, if you change the text, you might get reflow and you could end up with text from B getting sent to C. Not the best practice, but it works.
    I’m not sure what you mean by “not changing their outline”…let us know.
    Erica Gamet
    Digital Dimensions
    https://www.digi-wizard.com/learn
    “…for there is nothing either good or bad, but thinking makes it so.”
