Activity › Forums › Adobe After Effects › Thoughts on muzzle flash
Posted by Michael Zoppo on July 3, 2007 at 5:16 amLooking for any advice on how to make this look better, feel free to say whatever you want about it, I just need some input, and yes I am going to get the red cap fixed on the end of the gun.
Kevin Camp replied 19 years, 2 months ago 6 Members · 5 Replies -
Scott Roberts
July 3, 2007 at 5:24 amLooks good!
Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
https://www.littleblackbird.com
Frank Hardie
July 3, 2007 at 10:40 amMuzzle flash “may” be just a touch too big.
I’d scale it down a little, but that’s just my personal preference.
Otherwise, looking good.
David Taylor
July 3, 2007 at 12:55 pmI say a tutorial somewhere that also showed how to add a light flash effect to the shooter. i.e. the light from the flash of the barrel casting on the shooter.
DT Motion Pictures
https://www.davetaylormp.com -
Darby Edelen
July 3, 2007 at 2:33 pmThat’s one of the better muzzle flashes I’ve seen created in post in terms of execution. If you really want to get crazy you should look at reference material to see what a muzzle flash from a gun like that (but more… real) would look like.
If I have any advice it’s to lower the smoke’s opacity some, add a cartridge popping out the side of the gun (which could be as simple as a light solid masked and moving VERY quickly with motion blur on) and maybe look at adding a tiny bit of light flash on the shooter. There shouldn’t be very much light flash on the shooter as your footage is in a bright environment already, it would have to be subtle to look ‘real.’
Kevin Camp
July 3, 2007 at 2:52 pmandrew kramer’s videocopilot has some good tuts on muzzle flashes, one steps thru adding lighting effects on the scene and subject as the flash occurs.
Kevin Camp
Designer – KCPQ, KMYQ & KRCW
