Activity Forums Apple Final Cut Pro Thoughts on 7D and Green Screen–deliverable is projected
  • Thoughts on 7D and Green Screen–deliverable is projected
    Posted by Michael Hadley on February 28, 2012 at 8:22 pm
    Hey Folks:
    Have a project coming up with a Pro Res deliverable being projected on a 20′ screen. Concept is green screen. A couple of questions:
    >>Any feedback on results keying with a 7D/TI? I know the 4-2-0 color spaces is less than ideal.
    >>Another option is to shoot with a Panny HDX 900, but that is native 720 (same 4-2-0 color space). SO there’d be the up rez to 1080 and not sure if that would be better than the 7D.
    Any advice here on 7D vs HDX900 and both vs. green screen appreciated. Thanks!
    Simon Ubsdell replied 14 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Christian Roth
    February 28, 2012 at 9:27 pm
    If you can manage the part of the red dot in post (which I suppose you can going green screen), you might consider recording the hdmi output of the 7D externally (KiPro f.i.) and thus avoiding the color space problem.
    kind regards, Chris.
  • T. Payton
    February 28, 2012 at 10:02 pm
    The 7D can’t do full rez 4:4:4 HDMI output.
    Regarding green screen work, the 7D does a great job. Proper lighting of your key as always is the trick.
    Also consider the end result and your audience. i.e. how good does the key have to look. Are you building a virtual set (CG elements) or are you trying to sell an actor in an environment. A virtual set can get away with a “rougher” key than trying to put an actor in a natural environment.
    And I must boast about the FCP X keyer. I grabbed a job I did a couple of years ago that was shot on HDV 4:1:0 on blue screen (it was short notice and that is all we had) and matts were created in Keylight in AE. The renders from key light had taken about an hour for a 5 minute clip. So I opened this up in FCP X and it was pulling a key just as good as Keylight AND IN REAL TIME!
    T. Payton
    OneCreative, Albuquerque
  • Michael Hadley
    February 29, 2012 at 3:55 am
    Thanks. I’m looking forward to using the keyer in X. That said, my concerns for the 7d is that the end result will be digitally projected on a 20′ screen for a corporate event, so the key will need to be pretty tight.
    Best,
    Mike
  • T. Payton
    February 29, 2012 at 3:33 pm
    I’m sorry Michael I didn’t actually answer your question 😉 The 7D should work very well. There have been several tests done in Vimeo. For example
    https://vimeo.com/7964527
    https://vimeo.com/7954098
    I failed to mention that my HDV keying project was projected on a 15 ft screen and looked very good. Therefore because of the inheritant quality advantages a 7D codec has over HDV, I would concluded that the 7D footage will pull a very good key, IF it is lit correctly.
    However, of course nothing can replace your own testing with your lighting setup, lens, etc. and projected on the largest screen you can get a hold of.
    T. Payton
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Michael Hadley
    February 29, 2012 at 3:47 pm
    Yeah, those keys look good.
    For this project, I’m looking at 2 7Ds, which on the plus side are 1080, but on the down side are only 4-2-0 color space for keying OR
    2 Panasonic HDX 800 which on the plus side are 4-2-2 but on the down side 720P, which will need to be uprezzed to pro res and then projected on a 20 foot screen.
    Neither is ideal. I’m tempted to go with the 7Ds, just a little leery of the keys, especially when blown up/projected.
    No lorries on the lighting side. The DP is great.
    Thanks again.
  • Brian Mulligan
    February 29, 2012 at 4:40 pm
    All Chroma-keys look great when viewed in B&W. It hides a multitude of sins.
    Brian Mulligan
    Senior Editor – Autodesk Smoke
    WTHR-TV Indianapolis,IN, USA
    Twitter: @bkmeditor
  • T. Payton
    February 29, 2012 at 4:43 pm
    Actually here is more with that 7D footage and in color:
    https://vimeo.com/7972379
    https://vimeo.com/15094759
    T. Payton
  • Simon Ubsdell
    February 29, 2012 at 4:57 pm
    If you want to get serious about keying, I strongly recommend you have a look at the offerings from Conduit (from the makers of DV Garage), which now include a Beta version for FCPX:
    https://www.dvgarage.com/conduit-64bit-beta
    Conduit is a nodal compositor (a sort of mini-Shake) that is optimized for keying and the results are truly outstanding, once you have learned what you are doing. Their training materials are the best introduction to the real science of keying that you can find and well worth looking at even if you don’t end up buying the product (whcih is insanely good value!).
    Particularly useful for cases like yours are their strategies for dealing with compressed source material of the 4:2:0 or 4:1:0 variety.
    With Conduit you will be able to get results far superior to anything you could hope for with any one-stop keyer, even one as good as the one now in FCPX.
    Disclaimer: I have nothing to do with Conduit or the organization that makes it.
    Simon Ubsdell
    http://www.tokyo-uk.com
