Activity › Forums › Apple Final Cut Pro Legacy › Thought I digitized DV 4:3. Got NTSC 3:2 in sequence setting. Do I Need to re-digitize media?
  • Thought I digitized DV 4:3. Got NTSC 3:2 in sequence setting. Do I Need to re-digitize media?
    Posted by Rodney J on November 24, 2005 at 1:18 pm
    Thought I was digitizing to DV NTSC 4:3 in Easy Setup, must of slipped because I got NTSC 3:2 720×480 in the sequence settings menu and when I change that setting to NTSC 4:3, under sequence settings, I get the Red Render Ling? Do I need to re-digitize the footage to the proper codec or is there something else I’m missing? If so what is the correct way to delete the old media and project.
    RJ
    Jerry Hofmann replied 20 years, 10 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    November 24, 2005 at 2:42 pm
    no… just use the preset that easy setup sets up…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
