Activity Forums Adobe After Effects those wavy edges
  • those wavy edges
    Posted by Will Martindale on April 19, 2007 at 1:20 pm
    Im doing this student project which realies on the Cartoonification process on live actors infront of a green screen, ive taken it through and got the look i want, but when i play the ai sequence back i get these wavy edges. i realise as part of the process this was going to be a result, but wondered if anyone had any ideas/if it was possible to limit the ‘wavyness’ of it all.
    Cheers.
    vid example https://www.youtube.com/watch?v=4vgvDPSFRLE
    Darby Edelen replied 19 years, 4 months ago 4 Members · 5 Replies
  • David Bogie
    April 19, 2007 at 4:17 pm
    > i get these wavy edges. < Nicely done effects, congrats on getting this far. The resolution of youtuoob is not adequate for me to guess at what you might mean. "Wavy line" inquiries are usually elementary field interpolation issues around here. That YT clip looks like it simply suffers from standard YT compression artifacts. You'd have to provide a higher rez sample for us to start throwing suggestions at you. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Sam Moulton
    April 19, 2007 at 6:04 pm
    youre seeing fields
    make sure you separate fields then when you render, don’t put them back in
  • Darby Edelen
    April 19, 2007 at 8:12 pm
    What was the process you used for this? It sounds like you generated the look frame by frame in Illustrator and imported a sequence. If that’s the case did you use auto-trace to generate the look? I’m not as familiar with Illustrator as Photoshop and AE but I think that a certain amount of inconsistency from frame to frame is inevitable unless you tweak your results really well. You could also try smoothing the vectors you get, but I don’t know how much that will help.
  • Will Martindale
    April 20, 2007 at 9:41 pm
    i’m not familair with auto trace or how to smooth my vectors in illustrator. I did literally follow the cartoonifacation process, the keyed real footage did not have the wavy edges and im sure i did seperate the fields, so im thinking it is just a result of the live trace process.
    would smoothing the vectors help? if so il learn what its all about
    cheers.
  • Darby Edelen
    April 21, 2007 at 6:12 am
    [Will Martindale] “the cartoonifacation process”
    I’m not familiar with the process, so that might be part of the problem =)
    I forgot that it’s Live Trace in Illustrator, I was thinking of the Auto Trace feature in AE.
