Activity Forums Adobe After Effects Thomson Viper (FilmStream) LUT for AE
  • Thomson Viper (FilmStream) LUT for AE
    Posted by Martin Fisher on July 14, 2010 at 2:32 pm
    Hi there,
    I’m working on a feature film shot with a Thomson Viper.
    The footage i received is green tinted, which is normal because of the FilmStream.
    I have to make some chroma keying and compositing/vfx work on this shots, so i need a LUT. I’ve been searching all over and i cant find any. So any tips on how to make one will be much appreciated.
    Also, if anyone has some experience working with this kind of footage i’d love to know whats your workflow, as this is my first time with this files.
    Thanks.
    M.
    Martin Fisher replied 16 years, 1 month ago 3 Members · 5 Replies
  • Martin Fisher
    July 14, 2010 at 3:09 pm
    Dave, Im using CS4 and CS5.
    CS5 has the “apply color LUT” utility, but i couldnt find any .3dl or .cube LUT files for the Viper.
    I also own Color Finesse, which can export LUTs. But i dont really know what parameters i should change to make a propper Viper LUT.
    Thanks.
    M.
  • Martin Fisher
    July 14, 2010 at 7:52 pm
    “I never have to deal with LUTs.”
    So whats your workflow with Viper footage ? Do you color correct it or you just work with the green look ?
    Thanks for the link Dave, but i dont really understand that spreadshet. I simply dont know how to translate it to AE. Any tips on that ?
    Thanks again.
    M.
  • Chris Wright
    July 15, 2010 at 6:35 pm
    software to fix Viper’s ringing glitches, and lut building, auto and manual how-to’s. There’s professional lut building software and then there’s the good old fashioned human eyeball, depends on your budget.
    https://www.lightillusion.com/viper.htm
    https://technicolorsoftware.hostzi.com/
  • Aaron Newsome
    July 16, 2010 at 12:36 pm
    I own a Viper camera and I do shoot in filmstream mode. There is no special LUT that is needed to remove the green tint. You can balance the color with standard color correction tools. This is much more precise if a chip chart was shot.
  • Martin Fisher
    July 17, 2010 at 12:27 pm
    thank you all of the help.
    m.
