Activity Forums Adobe After Effects Expressions thisLayer.index For Parameter
  • thisLayer.index For Parameter
    Posted by Mike LeBel on September 11, 2020 at 9:23 pm
    I’m trying to do something fairly basic but am coming across a repeated issue. I’d like to refer scaling in another Comp, but not choose a specific layer name. Instead I’d like to use the same layer number where I’m calling it from. The error is the same each time “BAD ARGUMENT. LAYER INDEX OUT OF RANGE EXPRESSION DISABLED”
    ReadScale=comp(“MyComp”).layer(4).transform.scale[0] //**Works well
    ReadScale=comp(“MyComp”).layer(“RefLayer”).transform.scale[0] //**Works well
    ReadScale=comp(“MyComp”).layer(thisLayer.index).transform.scale[0] //**Does not work
    ReadScale=comp(“MyComp”).layer(x).transform.scale[0] //**Does not work (where “x=5”)
    It seems as though no variable can be inserted into this location. I am able to use the following in another expression for a different parameter. But when I put it all together it still does not work.
    parseInt((thisLayer.index)-2 //**Works correctly
    Any feedback or food for thought would be greatly appreciated!
    -Thanks!
    Stephen Dixon replied 5 years, 11 months ago 5 Members · 4 Replies
  • Andrei Popa
    September 12, 2020 at 10:09 am
    I tried to link my layer size to another size from another comp like this
    ReadScale=comp("Comp 1").layer(index).transform.scale[0]
    [ReadScale,ReadScale]
    It did not work, but the 2nd row was the problem. I tried adding a new array and setting its value to [ReadScale,ReadScale] and it worked. Maybe this is your problem?
    x = [ReadScale,ReadScale];
    x
  • Filip Vandueren
    September 12, 2020 at 11:29 am
    Hi Mike,
    your example works without a problem for me, both in Legacy Extendscript and Javascript engines. (Mac OS X)
  • Chris Voelz
    September 15, 2020 at 8:03 pm
    This also worked for me.
  • Stephen Dixon
    September 18, 2020 at 5:32 am
    Maddeningly AE layer indexes start at 1, not zero, so any loops that reference indexes have to start at 1. That could be your problem. Either that or for some reason you’re trying to reference a layer index that doesn’t exist.
    Also
    How can this work correctly? You’re missing a bracket on the right hand side, and parseInt is for converting strings into ints.
