Activity Forums Adobe Premiere Pro “This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type”
  • “This project contained a sequence that could not be opened. No sequence preview preset file or codec could be associated with this sequence type”
    Posted by Tom Miller on January 6, 2015 at 12:28 pm
    Hello
    I can’t open any of my files I have been working on!
    I have seen a work around for this problem that involves opening in a text editor but when I do that it opens a file of random characters – no words in there at all to change!
    Thanks for viewing! It is driving me mad!
    Tom
    Job Jansweijer replied 11 years, 8 months ago 3 Members · 2 Replies
  • Ann Bens
    January 7, 2015 at 12:29 am
    https://helpx.adobe.com/premiere-pro/kb/features-presets-missing-premiere-pro.html
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Job Jansweijer
    January 7, 2015 at 10:53 am
    Did you also try to open in notepad or dreamweaver?
    I imagine word gives strange characters.
    I had a similar problem, and this was the solution for me in the end:
    1) Create a new (empty) project file with your desired settings
    2) Go to file > import and select the Premiere Pro file that gave you the error (you can import premiere projects)
    3) Choose the option to select which sequences to import
    4) Select the sequence(s) you need
    5) Continue your work in the new project
    Probably, the only reason this worked for me was because the sequence giving the error was another sequence than the one I need, but it’s worth a try, because it’s a relatively simple solution if it works.
