Activity › Forums › Apple Final Cut Pro Legacy › This one feature alone may be worth the price of admission
Aaron Neitz replied 17 years, 1 month ago 11 Members · 13 Replies
Lu Nelson
July 25, 2009 at 6:36 pmYou can nudge position of an item using option-arrowkey, if you have the canvas selected; I believe adding the shift key in to this combination may nudge it by larger amounts.
Otherwise, you can also alter most motion tab controls by hovering the mouse over the control and rolling your mousewheel…
Most motion tab stuff is pretty quick to use I find, given the mouse-wheeling but I absolutely agree that keyframing has always sucked and it seems continues to suck
Lu Nelson
Berlin, Germany
[MacProQ2.66, 8GB, Sys10.5.6, FCP 6.0.5, AE 9.0.2] -
Arc Nevada
July 27, 2009 at 7:03 pmAlex Udell,
Why would you switch from CS4 to FCS? I used to use Edius but switched to CS4 because of the integration between the CS4 programs. I like the fact the the GUI is the same for Sound Booth, AE, Encore etc.
There is nothing wrong with FCS or CS4. The choice would have to depend on your needs (video, audio, web graphic art). You could jump ship the FCS now but will you jump back to Adobe when CS5 ships?
What is making you want to jump ship?
Aaron Neitz
July 27, 2009 at 8:46 pmAMAZING. thank you
I really ought to take a FCP class sometime and find out all these little tricks. I’ve got 6 years of bad habits that could use some polishing
